Solved: A2plus: move object jumps to cursor
When I try to use the move object function on A2plus, the object I have selected jumps to my cursor as soon as my cursor enters the active window, after clicking the "move object" icon. I recorded a video of use as mp4 (shrunk to 100 k) but I get an error if I try to attach it, so this pair of screenshots will have to do.
Any suggestions? I updated A2plus in the addon manager, restarted, and its still the same.
Thanks in advance
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
This is not the behavior I was expecting.. it would be better if the objects stayed in place until I clicked on them and tried to drag them around. Any suggestions? I updated A2plus in the addon manager, restarted, and its still the same.
Thanks in advance
Qt version: 5.6.2
Re: A2plus: move object jumps to cursor
For creating screenshots it is very easy to use the snippet tool.
As I've never needed the functionality you request (I just scatter the A2Plus objects somewhere near and then apply the appropriate constraints to take them to the correct location), this is a workaround that I'm sure can be turned into a short-cut key combination instead:
1) Click on the object in Tree view
2) Move cursor over highlighted object in 3D View
3) Press Alt-M keys to open Macro menu
4) Right arrow cursor key to open A2Plus menu
5) Down arrow cursor key x 3 for Move command
6) Return/Enter key to activate Move function
OS: Windows 7
Qt version: 5.6.2
A2Plus 0.4.31
OS: Windows 7
Qt version: 5.6.2
A2Plus 0.4.31
This, the Assembly forum, is obviously the right place to discuss issues about the Assembly workbenches.
However, since A2plus is an external workbench, it makes sense to directly contact its author, and send requests to the GitHub page of that project.
Further to the workaround I mentioned earlier if you change the file a2p_importpart.py around line 1056 from:
to
This gives you the keyboard shortcut MP. Therefore you can open your assembly file, change to the A2Plus Wb click the object to move in the Tree View, hover your cursor over the object on the 3D view and press the M key followed by the P key and it will activate the move command.
def GetResources(self):
return {
#'Pixmap' : ':/assembly2/icons/MovePart.svg',
'Pixmap' : a2plib.pathOfModule()+'/icons/a2p_MovePart.svg',
'MenuText': 'Move the selected part',
'ToolTip': toolTip
return {
'Accel' : "M, P",
'ToolTip': toolTip
Thanks vocx. I hope kbwbe is happy when he is conntacted.
Yes, that's what I did. Just pasted them both into paint to make them one image, and shrink size.
I do the same thing for initial assembly. But then I want to make adjustments, and if the object leaps out of place and needs to be dragged back and repositioned, it gets distracting and takes time, and would be a real impediment for large or complex assemblies.
It's not so much that I can't use the software like this, but I want it to improve over time so FreeCad gets more awesome, so I'm reporting the bug/feature.
Ok I contacted kbwbe about this. But aren't all the assembly workbenches in FreeCad external? So shouldn't it be ok to discuss them here in the Assembly forum? Not trying to be difficult, just trying to understand how this place works.vocx wrote: ↑Tue Dec 17, 2019 7:19 pmThis, the Assembly forum, is obviously the right place to discuss issues about the Assembly workbenches.
