How to make an axis visible of and circular part
AshAsh
Post by AshAsh » Sun Dec 29, 2019 1:44 pm
I wish to know how to make the Axis visible of a circular part when i am doing A3plus i am trying to make an axis constraint
between two circular parts but i cannot activate visibility of the axis of the two parts, Thanks
Re: How to make an axis visible of and circular part
Post by chrisb » Sun Dec 29, 2019 6:23 pm
Moved to Assembly forum (and I guess it's A2plus, not A3plus).
dan-miel
Post by dan-miel » Mon Dec 30, 2019 10:52 am
Hi ashash, I don't think there is an Axis in these parts. kbwbe removes the planes from the parts when the parts are imported , I'm guessing there is not an axis to be found either.
Dan.
Syres
Post by Syres » Mon Dec 30, 2019 12:13 pm
i am trying to make an axis constraint between two circular parts
I think this maybe a communication clarity issue or maybe a A2Plus version difference so firstly please check the version I used to produce these screenshots at the bottom of this post.
The constraint to align two circular items is CircularEdge, in the past I believe it was Axis Constraint. If you look at the following screenshots you will see which edges I selected on the manifold and the dowty washer and then the constraint set at zero for them to align. When aligning the BSPP adaptor to the dowty washer I had to use an offset of 15mm to achieve the desired result in this case.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19060 (Git)
Hash: 72065b0d3960ec9b4aa90cce1a6e810e8bab68c4
Python version: 3.6.8
Qt version: 5.12.1
A2Plus v0.4.35
dan-miel
Post by dan-miel » Wed Jan 08, 2020 3:22 pm
To clarify my answer. Cylinders and holes has an axis in the center of them. In many CAD programs you can make the axis visible, like the picture below, so you can see if they are where you think they are. AshAsh asked about axis visibility twice and I don't think we can make the axis visible. But reviewing his question he is trying to connect two round parts. I would say that your answer is the one he was looking for.
Dan Miel
AshAsh
Post by AshAsh » Fri Jan 10, 2020 4:59 pm
Thanks guys for your responce.
Yes when I try to connect two edges the centre of mass gets highlighted instead of the circular edge constraint and also if the two different circular parts are of a different size I cannot constraint them.
Moreover if the axis is visible in A2plus it serves two purposes one constrainting two different part of different sizes and also you can rotate the other part with the mouse as display for example if you constraint a hinge of a door by axises you can open and close this way.
if any can write a code to make it visible it would be very convient as I am not a python guy.
Cheers.
dan-miel
Post by dan-miel » Sat Jan 11, 2020 4:59 pm
If you select two cylinders the axisCoincindent should be enabled and should work. I will work on any combination of round surfaces, (holes or cylinders), and edges.
I hope this helps.
Dan
Axis coincindent.JPG (9.89 KiB) Viewed 270 times
AshAsh
Post by AshAsh » Sun Jan 12, 2020 2:24 pm
Hi Dan,
Thanks for the Help, I got the axis constraint to work with highlighting cylinders but the Part sticks on, the newly added part has got no circular
motion with click and hold of the mouse. is there any solution for this.
Cheers.
dan-miel
Post by dan-miel » Mon Jan 13, 2020 1:02 am
There is a new function that might help. The icon is below. Says to click button, select part and it will move within it's degrees of freedom. or something like that.
What CAD are you used to?
Dan
Part mover.JPG (10.57 KiB) Viewed 204 times
AshAsh
Post by AshAsh » Tue Jan 21, 2020 2:44 pm
Hi Dan,
Thanks for the Info, I have been with a lot of employers and everyone had something different, mostly they have solidworks, well I have jumped off the employment bandwagon and have been trying to develop something myself hence freecad was the best option as I cannot afford the fancy ones.
Cheers.
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
