Frecad 0.19 Possible bug in assembly4
jruiz
Post by jruiz »
Playing with Assembly 4 workbench found the following:
If in a file FA a link to spreadsheet in another file FB is made, Assembly4 model fail when inserting a link to external part, skipping the step of placing linked part and in the report view the message:
created object
Running the Python command 'Asm4_placeLink' failed:
File "~/FreeCAD/Mod/Assembly4/placeLinkCmd.py", line 111, in Activated
if hasattr(obj,'LinkedObject') and obj.LinkedObject.isDerivedFrom('App::Part'):
'tuple' object has no attribute 'isDerivedFrom'
appears.
If the spreadsheet link is deleted, Assembly4 works as expected.
Regards,
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.19107 (Git) AppImage
Hash: ad952191297fe53593c4d4b0ac80b43fd6664b22
Python version: 3.7.6
Qt version: 5.12.5
Locale: Spanish/Venezuela (es_VE)
I have uploaded many FreeCAD video tutorials to my YouTube channel
Zolko
Re: Frecad 0.19 Possible bug in assembly4
Post by Zolko »
jruiz wrote: Fri Jan 03, 2020 9:11 am If in a file FA a link to spreadsheet in another file FB is made, Assembly4 model fail when inserting a link to external part
hello, thank-you for your bug report, but I'm not sure to completely understand what you do: is there a third file FC involved, where you do the linking of FA ? Could-you provide a screenshot of your model tree with all parts and links ?
jruiz
Post by jruiz »
is there a third file FC involved...?
Nope.
In FA I make a link to the spreadsheet of FB
Hope that the attached (sequence of) images let me explain better that my poor english :D ...
Zolko
Post by Zolko »
jruiz wrote: Tue Jan 21, 2020 1:15 pm In FA I make a link to the spreadsheet of FB
so you have a file FB with a spreadsheet and a part. Then, in file FA you make an empty link, you assign the spreadsheet of FB to it, and then in FA you create an Assembly4 Model and you link the part from FB using Assembly4 tools ...
1) you shouldn't do horrible things like that
2) it's still a bug, and Assembly4 shouldn't fall for it
I made an update to the workbench (v0.7.10), can you please update (through the Addon Manager) and check again whether it works better now ?
jruiz
Post by jruiz »
Just wondering. Could you order things as you see their ugliness increase?
Do you realize that your comment is highly subjective?
Assembly4 I am using is updated to version v0.7.10
Zolko
Post by Zolko »
jruiz wrote: Tue Jan 21, 2020 3:33 pm Assembly4 I am using is updated to version v0.7.10
And ? Do you still get the same bug ?
jruiz
Post by jruiz »
Yes.
Since my first post here i was using version v0.7.10 of Assembly4.
Zolko
Post by Zolko »
jruiz wrote: Tue Jan 21, 2020 3:51 pm Since my first post here i was using version v0.7.10 of Assembly4.
that's obvious BS because I uploaded that version 30 minutes ago. See the Release Notes.
jruiz
Post by jruiz »
Zolko wrote: Tue Jan 21, 2020 3:57 pm
that's obvious BS...
What exactly you mean with "BS"?
Zolko wrote: Tue Jan 21, 2020 3:57 pm ...because I uploaded that version 30 minutes ago. See the Release Notes.
After a quick use of the addon manager for updating Assembly4. I got a message I did not understand (as you could note, english is not my spoken language) and I assumed it was updated, (Very first time I got that behavior from the addon manager).
It is very curious that you use the word random in the release notes
https://github.com/Zolko-123/FreeCAD_As ... ease-notes
2020.01.21 (version 0.7.10) :
bug-fix to not fall for random criss-cross linking of objects
when the behavior we got from Assembly4 is completely deterministic.
adrianinsaval
Post by adrianinsaval »
jruiz wrote: Tue Jan 21, 2020 5:00 pm After a quick use of the addon manager for updating Assembly4. I got a message I did not understand (as you could note, english is not my spoken language) and I assumed it was updated, (Very first time I got that behavior from the addon manager).
What message did you get? Did you manage to update? Is the bug solved?
Also, what is your native language? If it's spanish I speak it and can help you out.
