FC 01.9 / A2Plus-WB ... A2p_example-for-dragging-animation.FCStd ... requires v0.4.38
lutz_dd
Post by lutz_dd » Wed Jan 08, 2020 10:24 pm
My goal is to use the command "Move the part under rule of constraints." as described by the example A2p_example-for-dragging-animation.FCStd @ https://freecadweb.org/wiki/A2plus_Workbench
By intention I'm not using the Animation-WB respective a Python-Script in this case. The described dragging-function is what I like to get.
(I) While I try to move my own assembly I got surprising behavior. With a axisCoincident constraint the lever can just be moved along the constraint-axis ... not rotated around the axis ... regardless the rotation-setting (true, false).
(II.a) Trying A2p_example-for-dragging-animation.FCStd it behaves different too. If the lime-colored shape is selected no movement et all.
(II.b.0) balken_003 & balken_004 removed + try to move balken_002 ... no movement
(II.b.1) then delete the last circular constraint with the command active
(II.b.3) now balken_002 is moving across the entire scene ... with balken_001 shape-property fixed_Postion=false
No errors or warnings were reported by the system ... looks ok.
NavigationStyle: Gesture ... A2plus: V0.4.32
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18760 (Git) ... and FC 0.18 checked partially.
Hash: ef73ab5f3a330d3c44138f23290f8c9f7a334caf
Python version: 3.7.3
Qt version: 5.12.1
lutz_dd
Re: FC 01.9 / A2Plus-WB ... A2p_example-for-dragging-animation.FCStd ... requires v0.4.38
Post by lutz_dd » Wed Jan 08, 2020 10:30 pm
The dragging feature seems to be brand-new ... updated to v0.4.38 ... everything perfect.
I like the dragging feature ... Thx
PS. My own assembly is working too without changes.
Who is online
Users browsing this forum: No registered users and 1 guest
