Part-o-magic: Active Part/Body reinvented
DeepSOIC
Re: Part-o-magic: Active Part/Body reinvented
Post by DeepSOIC » Thu Aug 31, 2017 11:39 am
freecad-heini-1 wrote:
Thu Aug 31, 2017 11:00 am
What about top-down design with a skeleton model?
I call it "master sketch" approach. Yes, part-o-magic supports it (but so does PartDesign), you only need to import the master sketch into every Body/Module using Shapebinder. But technically, it doesn't have to be a sketch, it can be a whole another Body, or just about anything that has shape.
Please note that part-o-magic is broken on current version of FC, at least since rev. 11827 (probably quite a few commits up, I haven't finished investigation on what exactly has happened).
freecad-heini-1
Post by freecad-heini-1 » Thu Aug 31, 2017 12:11 pm
Thank you DeepSOIC for your answer. Please can you explain me a bit more how to deal with the master sketch. Is it a single part with different features, and if I create my device model, I need really to import that file into each active body?
eppo
Post by eppo » Tue Jan 07, 2020 12:18 am
Happy New Year all and thank you DeepSOIC for sharing the code.
Warning: i am totally new to FreeCAD, not a professional programmer either. There's that and if i'm wrong please ignore the rest.
In short, while exploring things managed to install Part-o-magic via Addon Manager. Note says "For FC v.0.17-18"
My FreeCAD version is:
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
After a restart of FC i found following error message:
Part-o-magic requires FreeCAD at least v0.17.9933. Yours appears to have a rev.4, which is less
Assuming FC versions and revisions are separately increasing numbers, well, i had changed my
c:\Users\User\AppData\Roaming\FreeCAD\Mod\Part-o-magic\PartOMagic\Base\Compatibility.py to following code
https://pastebin.com/4wqnmvUf
Addon here loads successfully since. I haven't explored features yet, there's no restriction to load addon on FC v.0.19.
Hope, helps.
DeepSOIC
Post by DeepSOIC » Wed Jan 08, 2020 4:48 pm
pushed a fix: https://github.com/DeepSOIC/Part-o-magi ... 28d3d06464
Thanks for reporting.
Who is online
Users browsing this forum: No registered users and 3 guests
