Part-o-magic [New: Selection tools, container duplication]
DeepSOIC
Re: Part-o-magic [New: Selection tools, container duplication]
Post by DeepSOIC » Fri Mar 01, 2019 12:49 pm
New tools:
* select children
* select children (recursive)
* select all
* invert selection
* selection buffer swap
Select children and select all react to holding Ctrl by not clearing the previous selection.
Select children (recursive) was mainly made to make deep copies of containers. For example, to duplicate a body, do this:
0. Deactivate all containers, or suspend PoM observer. (otherwise, "Object can only be in a single GeoFeatureGroup" error)
1. select the body.
2. holding Ctrl, invoke "select children (recursive)"
3. Edit->Duplicate. Answer "NO" to whether you want dependencies copied.
Thanks to recent fix by Werner, this will also work on part-o-magic containers (since v0.18.15994).
Selection buffer swap is a tool to help with complicated selection. For example, if you are selecting a long sequence of edges for a sweep, and in the middle of the work you realized you need to hide an object that gets in the way, the tool can help. You click the buffer swap, and what you've selected so far is saved to a buffer. Then you hide the offending object. Then clicking buffer-swap again restores the selection, and you can continue on selecting the edges.
I am still working on FCStd import-export, and container-aware object duplication. FCStd export is now available in File->Export dialog, but it gives FCStd1 extension (FreeCAD blocks .FCStd there). Export is more-or-less good, but import is very buggy.
DeepSOIC
Post by DeepSOIC » Fri Mar 01, 2019 11:47 pm
Select children (recursive) was mainly made to make deep copies of containers. For example, to duplicate a body, do this: ...
No, scratch that.
New tool!
* Duplicate
Can duplicate (deep copy) Parts, Bodies, PoM containers, and just objects.
EDIT: not so fast, the tool brings sketches into an uneditable state. Can be fixed by saving and reopening the project, but that's quite a serious bug right there.
Post by Kunda1 » Wed Jan 08, 2020 6:01 pm
Mod edit: @DeepSOIC (author of this thread and dev behind Part-o-magic) has asked this thread be locked in favor of the one specified in the OP.
Locked
Who is online
Users browsing this forum: No registered users and 3 guests
