But what you can do is to run the script and create two pulleys:
- First pulley (document GT2) 50 teeth, shaft 5mm with base
- Second pulley (document GT21) 32 teeth, shaft 5mm with base
- In document GT21 select the Gear object from the tree-view
- Then Ctrl+C for copy
- Go to document GT2
- Select the GT2 document from the treeview and do a Ctrl+P
- Then You will end with a Gear001 object.
- Select this object and right click the mouse to show the menu
- Select transform
- Move it upwards (Z axis) 6mm (or the height of your other pulley)
- Then select both Gear and Gear001 objects, go to Part Module and do a Fusion
- That's it!
You will end with something like:
-alex- wrote: ↑Fri Apr 26, 2019 5:03 pmThank you so much!
Could it be possible to get an option to select a 2 stages pulley? I could be very useful to modelise 3D printed driven pulley for reducer.
I though about this script: it could be great if it could be possible to select pulley, or gears, by mixing the gear WB features maybe?
I assume it's a hard work...
Anyway, thank you again.
