FreeCAD .FCStd importer for Blender 2.80
s-light
Re: FreeCAD .FCStd importer for Blender 2.80
Post by s-light » Thu Oct 31, 2019 1:47 pm
s-light wrote:
Wed Oct 30, 2019 9:47 pm
this one i can fix easily
or at least i thought so.. :lol:
you would need to rename the folder that is stored inside the zip...
now i have fixed the addon itself -
so it should work now!
(was issues/9)
and updated the readme.
sunny greetings
stefan
alxscott
Post by alxscott » Thu Oct 31, 2019 7:56 pm
(was issues/9)
sunny greetings
stefan
lol!! Worked perfectly, thank you very much! :)
Alex
vocx
Post by vocx » Sat Dec 21, 2019 12:35 am
s-light wrote:
Fri Oct 25, 2019 6:28 pm
so in the external listing i get 2 objects less - and this are:
* Body_Hex Body PartDesign::Body
* Pad Pad PartDesign::Pad
Do you still have this problem? I think we can call realthunder to take a look at why the objects aren't created.
What exactly is the "external listing"? Is it using FreeCAD as a library?
s-light
Post by s-light » Wed Jan 15, 2020 5:09 pm
yes - i import with
(source)
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
List Objects.
Stand-alone
import sys
import os
path_to_freecad = "/usr/lib/freecad-daily-python3/lib/FreeCAD.so"
def append_freecad_path():
    """Append the FreeCAD path."""
    global path_to_freecad
    if os.path.exists(path_to_freecad):
        if os.path.isfile(path_to_freecad):
            path_to_freecad = os.path.dirname(path_to_freecad)
        print("Configured FreeCAD path:", path_to_freecad)
        if path_to_freecad not in sys.path:
            sys.path.append(path_to_freecad)
    else:
        print("FreeCAD path is not correct.")
try:
    try:
        import FreeCAD
    except ModuleNotFoundError:
    import FreeCAD  # noqa
    print("FreeCAD version:", FreeCAD.Version())
except ModuleNotFoundError as e:
    print("FreeCAD import failed.", e)
and i just checked - with
`FreeCAD version: ['0', '19', '', 'https://code.launchpad.net/~vcs-imports/freecad/trunk', '2020/01/14 16:28:39']`
its the same.
i think this is not 'a realthunder thing' but more a real FreeCAD *core* thing...
yorik wrote:
Wed Oct 09, 2019 6:56 pm
Regarding your issues with bodies and not having the same number of objects in a same file, internally and externally: That's pretty worrying! Can you share a test file?
@yorik: what do you mean?
in
https://forum.freecadweb.org/viewtopic. ... 05#p343205
i have some test files linked.
you can directly find theme at:
- https://github.com/s-light/io_import_fc ... dy_objects BodyTest.FCStd
- https://github.com/s-light/io_import_fc ... ittleWorld MyLittleWorld.FCStd
- https://github.com/s-light/io_import_fc ... ng_example assembly_export.FCStd
vocx
Post by vocx » Wed Jan 15, 2020 5:33 pm
Yes, but since August last year, realthunder has been changing a lot of the core code. This could be solved by him in a matter of minutes if he identifies the problem.
I've been very lazy on this topic, which admitedly looks serious. However, your first test files and code seemed to me cumbersome. Too much information.
I'd like to ask you to prepare the absolutely simplest test file that you can think of. A single Body, a single feature, and a simple way to show the error.
s-light
Post by s-light » Wed Jan 15, 2020 6:13 pm
ok - as you requested -
i stripped all the nice formatting off ;-)
here is the *minimal* version:
BodyTest_Minimal.FCStd
and also attached:
(14.1 KiB) Downloaded 2 times
copy & paste for FreeCAD python console:
(source)
import FreeCAD
objects = FreeCAD.ActiveDocument.Objects
print("doc.Objects", len(objects))
for o in objects:
    print(o, o.Name)
copy & paste for python3 REPL:
(source)
import sys
path_to_freecad = "/usr/lib/freecad-daily-python3/lib/"
import FreeCAD
doc = FreeCAD.open("./BodyTest_Minimal.FCStd")
docname = doc.Name
for o in objects:
    print(o, o.Name)
FreeCAD.closeDocument(docname)
Who is online
Users browsing this forum: No registered users and 3 guests
