[Macro] Bit of help for super users :)
- HakanSeven12
Re: [Macro] Bit of help for super users :)
Looks good thanks
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- HakanSeven12
This isn't trivial question actually. I'm surely open to changes/improvements/new features.
But I think it shall be discussed with care. At first I think this macro shouldn't become a "put all in" one.
Also it shall keep it's spirit. And keep user readability while preventing duplicating other WB/macros.
What seems sensible to me is :
- Discuss here the changes (in terms of features essentially) so we hopefully have enough audience to take the right decision
- I'll soon publish it as a workbench (I think it's the way to go) on GitHub so you (anybody) can push changes as PR.
- HakanSeven12
ok My plan is merge with this: https://forum.freecadweb.org/viewtopic.php?f=22&t=44015
I think AutoHide can be a great feature.ATM, it has some major problems to solve :HakanSeven12 wrote: ↑Wed Mar 25, 2020 12:07 pm ok My plan is merge with this: https://forum.freecadweb.org/viewtopic.php?f=22&t=44015
- It doesn't restore correctly visible docks if FC is closed while the macro is active
- When active, it shows all available docks, and not only the ones that has been enabled. I think that merging into this macro can be a good way to implement a solution. Eg. user enabled docks could be turned green and only these will be shown. User can still enable/disable docks by clicking on the status bar icons.
- I prevent myself to introduce keyboard shortcuts. They can overlap and be a big mess. Here "Shift+C" and "Shift+M" just don't work
- The displayed info seems to me rather incomplete/useless. I though like how/what the Curves WB / Info tool displays. Having a mix of both (live select at hovering from yours + style/info of Curve WB could be pretty cool.
- LMB click to enable/disable AutoHide
- RMB click to enable/disable Info
- MMB and Wheel can still be used for extra functions
- HakanSeven12
Hi I like the slider font sizer. Do you want to add it to Modern UI?
Feel free to copy it. It should be pretty to isolate (code is by the end of the macro IIRC).HakanSeven12 wrote: ↑Sat Apr 18, 2020 9:00 pm Hi I like the slider font sizer. Do you want to add it to Modern UI?
But honestly, my thought was more to remove this tool from the FC_SU macro. Mainly because I found a lot of issues related to font propagation on Windows (that was mainly visible on Report view & Python console IIRC).
- HakanSeven12
- adrianinsaval
Hi! I added integration with Glass addon, glass mode can be toggled on/off with right click on C. I attach the edited macro if you are interested and here is the diff:
It doesn't reduce functionality of the macro or raise an error if the addon is not instaled.
276a277,283
> ## Glass addon integration
> def glass():
> try:
> Gui.getMainWindow().findChild(QtGui.QAction,GlassToggleMode).trigger()
> except AttributeError:
> pass
287c294
< ,[custDockToggler, [Combo View, C, getFCInfo]]
> ,[custDockToggler, [Combo View, C, getFCInfo,glass]]
308c315
< run()
\No newline at end of file
> run()
- FC_SU.py
- (11.69 KiB) Downloaded 33 times
Totally forgot about this macro!
Was this ever added to FreeCAD-macros repo? (or made available through the addon manager?)
