import sys
import math
import numpy
sys.path.append('/usr/lib/freecad/lib/')
import FreeCAD
import Draft
import Part
import BOPTools.JoinFeatures
doc = FreeCAD.newDocument('newdoc')
ZERO = 1e-10
def U(c, xl):
u = c[5]
if c[6] != 0:
t = c[0] + c[1] * abs((xl + c[2]) / c[3]) ** c[4]
if abs(t) <= ZERO:
t = 0
u += c[6] * t ** (1./c[7])
return u;
class Fuselage:
def H(xl):
if xl < 0.4:
c = [1.0, -1.0, -0.4, 0.4, 1.8, 0.0, 0.25, 1.8]
elif xl < 0.8:
c = [0.0, 0.0, 0.0, 0.0, 0.0, 0.25, 0.0, 0.0]
elif xl < 1.9:
c = [1.0, -1.0, -0.8, 1.1, 1.5, 0.05, 0.2, 0.6]
elif xl < 2.0:
c = [1.0, -1.0, -1.9, 0.1, 2.0, 0.0, 0.05, 2.0]
return U(c, xl);
def W(xl):
if xl < 0.4:
c = [1.0, -1.0, -0.4, 0.4, 2.0, 0.0, 0.25, 2.0]
elif xl < 0.8:
elif xl < 1.9:
elif xl < 2.0:
return U(c, xl);
def Z(xl):
if xl < 0.4:
c = [1.0, -1.0, -0.4, 0.4, 1.8, -0.08, 0.08, 1.8]
elif xl < 0.8:
c = [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
elif xl < 1.9:
c = [1.0, -1.0, -0.8, 1.1, 1.5, 0.04, -0.04, 0.6]
elif xl < 2.0:
c = [0.0, 0.0, 0.0, 0.0, 0.0, 0.04, 0.0, 0.0]
return U(c, xl);
def N(xl):
if xl < 0.4:
c = [2.0, 3.0, 0.0, 0.4, 1.0, 0.0, 1.0, 1.0]
elif xl < 0.8:
c = [0.0, 0.0, 0.0, 0.0, 0.0, 5.0, 0.0, 0.0]
elif xl < 1.9:
c = [5.0, -3.0, -0.8, 1.1, 1.0, 0.0, 1.0, 1.0]
elif xl < 2.0:
c = [2.0, 0.0, 0.0, 0.0, 0.0, 0.04, 1.0, 1.0]
return U(c, xl);
class Pylon:
def H(xl):
if xl < 0.8:
c = [1.0, -1.0, -0.8, 0.4, 3.0, 0.0, 0.145, 3.0]
elif xl < 1.018:
c = [1.0, -1.0, -0.8, 0.218, 2.0, 0.0, 0.145, 2.0]
return U(c, xl);
def W(xl):
if xl < 0.8:
c = [1.0, -1.0, -0.8, 0.4, 3.0, 0.0, 0.166, 3.0]
elif xl < 1.018:
c = [1.0, -1.0, -0.8, 0.218, 2.0, 0.0, 0.166, 2.0]
return U(c, xl);
def Z(xl):
if xl < 0.4:
c = [0.0, 0.0, 0.0, 0.0, 0.0, 0.125, 0.0, 0.0]
elif xl < 1.018:
c = [1.0, -1.0, -0.8, 1.1, 1.5, 0.065, 0.06, 0.6]
return U(c, xl);
def N(xl):
if xl < 0.4:
elif xl < 1.018:
return U(c, xl);
def yl(xl, phi, part):
return r(part.H(xl), part.W(xl), part.N(xl), phi) * math.sin(phi)
def zl(xl, phi, part):
return r(part.H(xl), part.W(xl), part.N(xl), phi) * math.cos(phi) + part.Z(xl)
def r(H, W, N, phi):
a = abs(0.5 * H * math.sin(phi)) ** N + abs(0.5 * W * math.cos(phi)) ** N
b = (0.25 * H * W) ** N
return (b / a) ** (1./N)
xm = numpy.linspace(0.00001, 2, 10)
xp = numpy.linspace(0.40001, 1.018, 10)
p = numpy.linspace(0, 2*math.pi, 10)
def makepart(part, x):
polygons = []
for i in range(len(x)-1):
points = []
for j in range(len(p)-1):
points.append(FreeCAD.Vector(x[i], yl(x[i], p[j], part), zl(x[i], p[j], part)))
points.append(points[0])
polygons.append(Part.makePolygon(points))
loft = Part.makeLoft(polygons)
cap1 = Part.Face(polygons[0])
cap2 = Part.Face(polygons[-1])
shell = Part.Shell(loft.Faces+[cap1, cap2])
Part.show(shell)
return shell
fuselage = makepart(Fuselage, xm)
pylon = makepart(Pylon, xp)
# join-connect fuselage and pylon
# let's call the joined object 'heli'
heli = BOPTools.JoinFeatures.makeConnect(name = 'Connected')
heli.Objects = [App.ActiveDocument.Shape, App.ActiveDocument.Shape001]
heli.Proxy.execute(heli)
heli.purgeTouched()
# make heli a solid
s = Part.Solid(Part.Shell(heli.Shape.Faces))
Part.show(s)
# make a sphere
sphere = Part.makeSphere(2,FreeCAD.Vector(1,0,0))
Part.show(sphere)
# cut heli from sphere
cut = sphere.cut(s)
Part.show(cut)
# extract seem of sphere
import CompoundTools.CompoundFilter
f = CompoundTools.CompoundFilter.makeCompoundFilter(name = 'CompoundFilter')
f.Base = App.ActiveDocument.Shape004
f.FilterType = 'window-volume'
f.Proxy.execute(f)
f.purgeTouched()
# make a line from seem of sphere to heli
line = Draft.makeWire([heli.Shape.Vertex27.Point, App.ActiveDocument.CompoundFilter.Shape.Vertex1.Point])
# split heli and line
import BOPTools.SplitFeatures
split = BOPTools.SplitFeatures.makeBooleanFragments(name= 'BooleanFragments')
split.Objects = [App.ActiveDocument.Shape004, App.ActiveDocument.Line]
split.Mode = 'Standard'
split.Proxy.execute(split)
split.purgeTouched()
import ObjectsFem
mesh = ObjectsFem.makeMeshGmsh(FreeCAD.ActiveDocument, 'FEMMeshGmsh')
FreeCAD.ActiveDocument.ActiveObject.Part = FreeCAD.ActiveDocument.Shape004
mr_fus = ObjectsFem.makeMeshRegion(FreeCAD.ActiveDocument, FreeCAD.ActiveDocument.FEMMeshGmsh, 0.5, 'fus')
for ii in range(1,len(App.ActiveDocument.Shape004.Shape.Faces)):
mr_fus.References.append((App.ActiveDocument.Shape004.Shape, App.ActiveDocument.Shape004.Shape.Faces[ii]))
print(len(mr_fus.References)) --> prints zero! why?
