Macro_cartoucheFC_Fully.py
drums488
Post by drums488 » Fri Jan 10, 2020 1:43 pm
Hello
New freecad user under Windows 10 1903 (up to date).
I downloaded freecad version 0.18
Then installed the macro "Macro_cartoucheFC_Fully.py"
and the layer sets A… .FULL.svg.
I open Freecad and make a new drawing. I choose a sheet to make the plan
and launches the "Macro_cartoucheFC_Fully.py" to fill the cartridge.
This returns the following error to me:
(‘Invalid syntax’, (‘G: / freecad macro / Macro_CartoucheFC_Full.py’, 1072, 17, ’print‘ ’run ,,‘ ’\ n’)))
Thanks for your help with a solution.
cordially
Drums
openBrain
Re: Macro_cartoucheFC_Fully.py
Post by openBrain » Fri Jan 10, 2020 1:58 pm
Looks like the macro isn't compatible with Python 3.
You can safely edit the macro and delete the faulty line.
Mario52 will probably tell us if he plans to update it. ;)
vocx
Post by vocx » Fri Jan 10, 2020 5:32 pm
Also, if I remember well, this macro was created for the Drawing Workbench which is obsolete since 0.17.
Therefore, I'm not sure if this macro produces a correct template that works with the TechDraw Workbench.
Ask Mario.
mario52
Post by mario52 » Sat Jan 11, 2020 10:16 pm
hi drums488
here only for FC 0.18 and Drawing Workbench Image
Macro_CartoucheFC_Full_FC018.FCMacro
# -*- coding: utf-8 -*-
from __future__ import unicode_literals
*   Copyright (c) 2014 2016 2017 2018 2019 2020 <mario52>                 *
*   This file is a supplement to the FreeCAD CAx development system.      *
*   This program is free software; you can redistribute it and/or modify  *
*   it under the terms of the GNU Lesser General Public License (LGPL)    *
*   as published by the Free Software Foundation; either version 2 of     *
*   the License, or (at your option) any later version.                   *
*   for detail see the LICENCE text file.                                 *
*   Use at your own risk. The author assumes no liability for data loss.  *
*              It is advised to backup your data frequently.              *
*             If you do not trust the software do not use it.             *
*   This software is distributed in the hope that it will be useful,      *
*   but WITHOUT ANY WARRANTY; without even the implied warranty of        *
*   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the         *
*   GNU Library General Public License for more details.                  *
*   You should have received a copy of the GNU Library General Public     *
*   License along with this macro; if not, write to the Free Software     *
*   Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  *
*   USA        *
*           WARNING! All changes in this file will be lost and            *
*                  may cause malfunction of the program                   *
#15/02/2017, 00.10-018
#OS: Windows 10
#Word size of OS: 64-bit
#Word size of FreeCAD: 64-bit
#Version: 0.18.4 (GitTag)
#Build type: Release
#Branch: releases/FreeCAD-0-18
#Hash: 980bf9060e28555fecd9e3462f68ca74007b70f8
#Python version: 3.6.6
#Qt version: 5.6.2
#Coin version: 4.0.0a
#OCC version: 7.3.0
__title__   = "Macro_CartoucheFC_Full_FC018"
__author__  = "Mario52"
__url__     = "http://www.freecadweb.org/index-fr.html"
__Wiki__    = "http://www.freecadweb.org/wiki/Macro_CartoucheFC_Full"
__version__ = "00.10-018"
__date__    = "2020/01/11"    #YYYY/MM/DD
__Requires__ = ("all version and freecad " +
" DESIGNED_BY, CREATION_DATE, CHECKED_BY, CHECK_DATE, SIZE, SCALE, WEIGHT, DRAWING_NUMBER, SHEET, " +
" TITLE, DESCRIPTION, COMPANY, COPYRIGHT, Note_A, Note_B, Note_C, Note_D, Note_E, Note_F, Note_G, Note_H, Note_I" )
__Template__ = " A3_Landscape_xx_FULL.svg, A3_Portrait_xx_FULL, A4_Landscape_xx_FULL.svg, A4_Portrait_xx_FULL"
__Template_Link__ = "http://www.freecadweb.org/wiki/index.php?title=Misc_templates_Full"
import PySide
import Draft, Part, FreeCAD, math, PartGui, FreeCADGui
from math import sqrt, pi, sin, cos, asin
from FreeCAD import Base
def utf8(unio):
    return unicode(unio).encode('UTF8')
global path
#path  = FreeCAD.ConfigGet("AppHomePath")
#path  = FreeCAD.ConfigGet("UserAppData")
#path  = "your path"
param = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Macro") # macro path
path = param.GetString("MacroPath","") + "/"                         # macro path
path = path.replace("\\","/")
#print("Path for the icons : " , path)
global PageActive      ; PageActive  = "Select your page" # essais
#global PageActive      ; PageActive  = "Page" # page active
global DESIGNED_BY     ; DESIGNED_BY = ""     # lineEdit01 DESIGNED_BY
global MDESIGNED_BY    ; MDESIGNED_BY = ""    #
global CREATION_DATE   ; CREATION_DATE = ""   # lineEdit02 CREATION_DATE date
global MCREATION_DATE  ; MCREATION_DATE = ""  #
global CREA_DATE       ; CREA_DATE = ""       # lineEdit02h date
global MCREA_DATE      ; MCREA_DATE = ""      #
global CREA_TIME       ; CREA_TIME = ""       # lineEdit02h heure
global MCREA_TIME      ; MCREA_TIME = ""      #
global CHECKED_BY      ; CHECKED_BY = ""      # lineEdit03
global MCHECKED_BY     ; MCHECKED_BY = ""     #
global CHECK_DATE      ; CHECK_DATE = ""      # lineEdit04 date
global MCHECK_DATE     ; MCHECK_DATE = ""     #
global CHEC_DATE       ; CHEC_DATE = ""       # lineEdit04 date
global MCHEC_DATE      ; MCHEC_DATE = ""      #
global CHEC_TIME       ; CHEC_TIME = ""       # lineEdit04h heure
global MCHEC_TIME      ; MCHEC_TIME = ""      #
global SIZE            ; SIZE = ""            # lineEdit05
global MSIZE           ; MSIZE = ""           #
global SCALE           ; SCALE =  ""          # lineEdit06
global MSCALE          ; MSCALE =  ""         #
global WEIGHT          ; WEIGHT =  ""         # lineEdit07
global MWEIGHT         ; MWEIGHT =  ""        #
global DRAWING_NUMBER  ; DRAWING_NUMBER = ""  # lineEdit08
global MDRAWING_NUMBER ; MDRAWING_NUMBER = "" #
global SHEET           ; SHEET =  ""          # lineEdit09
global MSHEET          ; MSHEET =  ""         #
global TITLE           ; TITLE =  ""          # textEdit_01
global MTITLE          ; MTITLE =  ""         #
global DESCRIPTION     ; DESCRIPTION =  ""    # textEdit_02
global MDESCRIPTION    ; MDESCRIPTION = ""    #
global COMPANY         ; COMPANY = ""         # textEdit_02b
global MCOMPANY        ; MCOMPANY = ""        #
global COPYRIGHT       ; COPYRIGHT = ""       # lineEdit_20
global MCOPYRIGHT      ; MCOPYRIGHT = ""      #
global Note_A          ; Note_A = ""          # lineEdit_10
global MNote_A         ; MNote_A = ""         #
global Note_B          ; Note_B = ""          # lineEdit_11
global MNote_B         ; MNote_B = ""         #
global Note_C          ; Note_C = ""          # lineEdit_12
global MNote_C         ; MNote_C = ""         #
global Note_D          ; Note_D = ""          # lineEdit_13
global MNote_D         ; MNote_D = ""         #
global Note_E          ; Note_E = ""          # lineEdit_14
global MNote_E         ; MNote_E = ""         #
global Note_F          ; Note_F = ""          # lineEdit_15
global MNote_F         ; MNote_F = ""         #
global Note_G          ; Note_G = ""          # lineEdit_16
global MNote_G         ; MNote_G = ""         #
global Note_H          ; Note_H = ""          # lineEdit_17
global MNote_H         ; MNote_H = ""         #
global Note_I          ; Note_I = ""          # lineEdit_18
global MNote_I         ; MNote_I = ""         #
global SymbolSwitch    ; SymbolSwitch = 1     # 0=US 1=EU
global ui              ; ui     = ""
def heure():
    return QtCore.QTime().currentTime().toString('hh:mm:ss')
def dateEu():
    return QtCore.QDate().currentDate().toString('dd/MM/yyyy') # forme euro
def dateUK():
    return QtCore.QDate().currentDate().toString('yyyy/MM/dd') # forme UK
def dateUs():
    return QtCore.QDate().currentDate().toString('MM/dd/yyyy') # forme US
def dateComp():
    return QtCore.QDate().currentDate().toString('dddd d MMMM yyyy') # Retourne "dimanche 20 Juillet 77"
try:
    _fromUtf8 = QtCore.QString.fromUtf8
except AttributeError:
    def _fromUtf8(s):
        return s
try:
    _encoding = QtGui.QApplication.UnicodeUTF8
    def _translate(context, text, disambig):
        return QtGui.QApplication.translate(context, text, disambig, _encoding)
        return QtGui.QApplication.translate(context, text, disambig)
def errorDialog(msg):
    diag = QtGui.QMessageBox(QtGui.QMessageBox.Critical,u"Error Message",msg)
    diag.setWindowFlags(PySide.QtCore.Qt.WindowStaysOnTopHint) # cette fonction met la fenetre en avant
    diag.exec_()
def symbol_EU(depx, depy, scale):    #symbol_EU =O
    global PageActive
    global ui
    try:
        page = App.activeDocument().getObjectsByLabel(PageActive.encode('utf-8'))[0]
    except Exception:
        page = App.activeDocument().getObjectsByLabel(PageActive)[0]
    if len(str(page)) != 2:
        comP   = []
        nameL  = []
        if "Page" in (page.Name):
            for ii in (page.Group):
                if ((ii.Label) == "Symbol_EU") or ((ii.Label) == "Symbol_US") :
                    App.activeDocument().removeObject(ii.Name)
        points=[FreeCAD.Vector(-7.5,0.0,0.0),FreeCAD.Vector(20.0,0.0,0.0)]
        i = Draft.makeWire(points,closed=False,face=False,support=None)
        comP.append(i.Shape)
        nameL.append(i.Name)
        points=[FreeCAD.Vector(12.5,7.5,0.0),FreeCAD.Vector(12.5,-7.5,0.0)]
        points=[FreeCAD.Vector(-5,2.5,0.0),FreeCAD.Vector(5.0,5.0,0.0),FreeCAD.Vector(5.0,-5.0,0.0),FreeCAD.Vector(-5.0,-2.5,0.0)]
        i = Draft.makeWire(points,closed=True,face=False,support=None)
        pl=FreeCAD.Placement()
        pl.Rotation.Q=(0.0,-0.0,-0.0,1.0)
        pl.Base=FreeCAD.Vector(12.5,-0.0,0.0)
        i = Draft.makeCircle(radius=2.5,placement=pl,face=False,support=None)
        i = Draft.makeCircle(radius=5.0,placement=pl,face=False,support=None)
        comp = Part.makeCompound(comP)
        Part.show(comp)
        App.ActiveDocument.ActiveObject.Label = "Symbol_EU"
        obj = FreeCAD.ActiveDocument.ActiveObject
        obj.ViewObject.LineColor = (0.0,0.0,0.0)
        obj.ViewObject.Visibility = False
        obj2 = Draft.makeDrawingView(obj, page)
        obj2.X = depx
        obj2.Y = depy
        obj2.Scale = scale #0.8    # A3
        obj2.Label = "Symbol_EU"
        for i in nameL: App.activeDocument().removeObject(i)
        App.activeDocument().getObject(page.Name).addObject(obj)
        App.activeDocument().getObject(page.Name).addObject(obj2)
    else:
        ui.pushButton05.setStyleSheet("background-color: red")       # This function gives a color button
        FreeCAD.Console.PrintError("Error selected page [ " + PageActive + " ]" + "\n")
def symbol_US(depx, depy, scale):    #symbol_US O=
    global PageActive
    global ui
    try:
    except Exception:
        comP   = []
        nameL  = []
        points=[FreeCAD.Vector(0.0,7.5,0.0),FreeCAD.Vector(0.0,-7.5,0.0)]
        points=[FreeCAD.Vector(7.5,2.5,0.0),FreeCAD.Vector(17.5,5.0,0.0),FreeCAD.Vector(17.5,-5.0,0.0),FreeCAD.Vector(7.5,-2.5,0.0)]
        pl.Base=FreeCAD.Vector(0.0,-0.0,0.0)
        Part.show(comp)
        App.ActiveDocument.ActiveObject.Label = "Symbol_US"
        obj2.X = depx
        obj2.Y = depy
        obj2.Label = "Symbol_US"
    else:
def memoEntree():
    global MDESIGNED_BY, MCREATION_DATE, MCREA_DATE  , MCREA_TIME, MCHECKED_BY, MCHECK_DATE
    global MCHEC_DATE  , MCHEC_TIME    , MSIZE       , MSCALE    , MWEIGHT    ,MDRAWING_NUMBER
    global MSHEET      , MTITLE        , MDESCRIPTION, MCOMPANY  , MCOPYRIGHT
    global MNote_A, MNote_B, MNote_C, MNote_D, MNote_E, MNote_F, MNote_G, MNote_H, MNote_I
    global PageActive
    try:
        page = App.activeDocument().getObjectsByLabel(PageActive.encode('utf-8'))[0].Name
    except Exception:
        page = App.activeDocument().getObjectsByLabel(PageActive)[0].Name
    try:
        MDESIGNED_BY   = App.activeDocument().getObject(page).EditableTexts[0]  # lineEdit01 DESIGNED_BY
        MCREATION_DATE = App.activeDocument().getObject(page).EditableTexts[1]  # lineEdit02 CREATION_DATE date
        MCREA_DATE = MCREA_TIME = MCHEC_DATE = MCHEC_TIME = ""
        try:
            MCREA_DATE = MCREATION_DATE.split(" - ")[0]                         # lineEdit02h date
        except:
        try:
            MCREA_TIME = MCREATION_DATE.split(" - ")[1]                         # lineEdit02h heure
        except: None
        MCHECKED_BY = App.activeDocument().getObject(page).EditableTexts[2]     # lineEdit03
        MCHECK_DATE = App.activeDocument().getObject(page).EditableTexts[3]     # lineEdit04 date
        try:
            MCHEC_DATE = MCHECK_DATE.split(" - ")[0]                            # lineEdit04 date
        except:
        try:
            MCHEC_TIME = MCHECK_DATE.split(" - ")[1]                            # lineEdit04h heure
        except: None
        MSIZE = App.activeDocument().getObject(page).EditableTexts[4]           # lineEdit05
        MSCALE = App.activeDocument().getObject(page).EditableTexts[5]          # lineEdit06
        MWEIGHT = App.activeDocument().getObject(page).EditableTexts[6]         # lineEdit07
        MDRAWING_NUMBER = App.activeDocument().getObject(page).EditableTexts[7] # lineEdit08
        MSHEET = App.activeDocument().getObject(page).EditableTexts[8]          # lineEdit09
        MTITLE = App.activeDocument().getObject(page).EditableTexts[9]          # textEdit_01
        try:
            MDESCRIPTION = App.activeDocument().getObject(page).EditableTexts[10]   # textEdit_02
            MCOMPANY = App.activeDocument().getObject(page).EditableTexts[11]       # textEdit_02b
            MCOPYRIGHT = App.activeDocument().getObject(page).EditableTexts[12]     # lineEdit_20
            MNote_A = App.activeDocument().getObject(page).EditableTexts[13]        # lineEdit_10
            MNote_B = App.activeDocument().getObject(page).EditableTexts[14]        # lineEdit_11
            MNote_C = App.activeDocument().getObject(page).EditableTexts[15]        # lineEdit_12
            MNote_D = App.activeDocument().getObject(page).EditableTexts[16]        # lineEdit_13
            MNote_E = App.activeDocument().getObject(page).EditableTexts[17]        # lineEdit_14
            MNote_F = App.activeDocument().getObject(page).EditableTexts[18]        # lineEdit_15
            MNote_G = App.activeDocument().getObject(page).EditableTexts[19]        # lineEdit_16
            MNote_H = App.activeDocument().getObject(page).EditableTexts[20]        # lineEdit_17
            MNote_I = App.activeDocument().getObject(page).EditableTexts[21]        # lineEdit_18
        except Exception:
            App.Console.PrintError("Erreur cartouche level DESCRIPTION (Missing field)"+"\n"
                        "You may be using an inadequate template. Try with this template"+"\n")
            App.Console.PrintMessage("http://www.freecadweb.org/wiki/index.php?title=Misc_templates_Full"+"\n\n")
            App.Console.PrintError("Or for the original FreeCAD template use this macro"+"\n")
            App.Console.PrintMessage("http://www.freecadweb.org/wiki/index.php?title=Macro_CartoucheFC"+"\n")
            errorDialog("Erreur cartouche level DESCRIPTION (Missing field)"+"\n"
                        "http://www.freecadweb.org/wiki/index.php?title=Macro_CartoucheFC"+"\n\n")
    except:
        errorDialog("Erreur cartouche")
class Ui_MainWindow(object):
    def __init__(self, MainWindow):
        global path
        global PageActive
        self.window = MainWindow
        self.path = path                   # macro path
        MainWindow.setObjectName(_fromUtf8("MainWindow"))
        MainWindow.resize(810, 400)
        MainWindow.setMaximumSize(QtCore.QSize(810, 400))
        self.centralWidget = QtGui.QWidget(MainWindow)
        self.centralWidget.setObjectName(_fromUtf8("centralWidget"))
#        self.pushButton01 = QtGui.QPushButton(self.centralWidget)
#        self.pushButton01.setGeometry(QtCore.QRect(115, 360, 93, 28))
#        self.pushButton01.setObjectName(_fromUtf8("pushButton01"))
#        self.pushButton01.clicked.connect(self.on_pushButton01_clicked) #connection pushButton01
        self.pushButton02 = QtGui.QPushButton(self.centralWidget)
        self.pushButton02.setGeometry(QtCore.QRect(225, 360, 93, 28))
        self.pushButton02.setObjectName(_fromUtf8("pushButton02"))
        self.pushButton02.clicked.connect(self.on_pushButton02_clicked) #connection pushButton02
        self.pushButton03 = QtGui.QPushButton(self.centralWidget)
        self.pushButton03.setGeometry(QtCore.QRect(335, 360, 93, 28))
        self.pushButton03.setToolTip("The memo button work only with the first Page")
        self.pushButton03.setObjectName(_fromUtf8("pushButton03"))
        self.pushButton03.clicked.connect(self.on_pushButton03_clicked) #connection pushButton03
        self.pushButton04 = QtGui.QPushButton(self.centralWidget)
        self.pushButton04.setGeometry(QtCore.QRect(445, 360, 93, 28))
        self.pushButton04.setObjectName(_fromUtf8("pushButton04"))
        self.pushButton04.clicked.connect(self.on_pushButton04_clicked) #connection pushButton04
        self.pushButton05 = QtGui.QPushButton(self.centralWidget)
        self.pushButton05.setGeometry(QtCore.QRect(555, 360, 93, 28))
#        self.pushButton05.setStyleSheet("background-color: red")       # This function gives a color button
        self.pushButton05.setObjectName(_fromUtf8("pushButton05"))
        self.pushButton05.clicked.connect(self.on_pushButton05_clicked) #connection pushButton05
        self.groupBox = QtGui.QGroupBox(self.centralWidget)
        self.groupBox.setGeometry(QtCore.QRect(20, 159, 190, 101))
        self.groupBox.setObjectName(_fromUtf8("groupBox"))
        self.label_20 = QtGui.QLabel(self.groupBox)
        self.label_20.setGeometry(QtCore.QRect(115, 5, 61, 17))
        self.label_20.setObjectName(_fromUtf8("label_20"))
        ############### font and color Label
        font = QtGui.QFont()
        font.setBold(True)
        self.label_20.setFont(font)
        self.label_20.setStyleSheet("color : #ff0000")
        self.label_20.setVisible(False)
        self.radioButton_0 = QtGui.QRadioButton(self.groupBox)
        self.radioButton_0.setGeometry(QtCore.QRect(95, 1, 91, 17))
        self.radioButton_0.setChecked(True)
        self.radioButton_0.setEnabled(False)
        self.radioButton_0.setVisible(False)
        self.radioButton_0.setObjectName(_fromUtf8("radioButton_0"))
        self.radioButton_1 = QtGui.QRadioButton(self.groupBox)
        self.radioButton_1.setGeometry(QtCore.QRect(95, 20, 91, 17))
        self.radioButton_1.setObjectName(_fromUtf8("radioButton_1"))
        self.radioButton_1.clicked.connect(self.on_radioButton_A3_clicked)# connect radioButton_A3
        self.radioButton_2 = QtGui.QRadioButton(self.groupBox)
        self.radioButton_2.setGeometry(QtCore.QRect(95, 39, 91, 17))
        self.radioButton_2.setObjectName(_fromUtf8("radioButton_2"))
        self.radioButton_2.clicked.connect(self.on_radioButton_A3_clicked)# connect radioButton_A3
        self.radioButton_3 = QtGui.QRadioButton(self.groupBox)
        self.radioButton_3.setGeometry(QtCore.QRect(95, 58, 91, 17))
        self.radioButton_3.setObjectName(_fromUtf8("radioButton_3"))
        self.radioButton_3.clicked.connect(self.on_radioButton_A4_clicked)# connect radioButton_A4
        self.radioButton_4 = QtGui.QRadioButton(self.groupBox)
        self.radioButton_4.setGeometry(QtCore.QRect(95, 76, 91, 17))
        self.radioButton_4.setObjectName(_fromUtf8("radioButton_4"))
        self.radioButton_4.clicked.connect(self.on_radioButton_A4_clicked)# connect radioButton_A4
        self.lineEdit_05 = QtGui.QLineEdit(self.groupBox)
        self.lineEdit_05.setGeometry(QtCore.QRect(10, 16, 75, 41))
        font.setPointSize(25)
        font.setBold(False)
        font.setWeight(50)
        self.lineEdit_05.setFont(font)
        self.lineEdit_05.setAlignment(QtCore.Qt.AlignCenter)
        self.lineEdit_05.setStyleSheet("color: red")           # origin system
        self.lineEdit_05.setObjectName(_fromUtf8("lineEdit_05"))
        self.lineEdit_05.setText(SIZE)
        self.frame = QtGui.QFrame(self.groupBox)
        self.frame.setGeometry(QtCore.QRect(10, 58, 74, 41))
        self.frame.setFrameShape(QtGui.QFrame.StyledPanel)
        self.frame.setFrameShadow(QtGui.QFrame.Raised)
        self.frame.setObjectName(_fromUtf8("frame"))
        self.radioButton_EU = QtGui.QRadioButton(self.frame)
        self.radioButton_EU.setGeometry(QtCore.QRect(0, 1, 41, 17))
        self.radioButton_EU.setChecked(True)
        self.radioButton_EU.setObjectName(_fromUtf8("radioButton_EU"))
        self.radioButton_EU.clicked.connect(self.on_radioButton_EU_clicked) #connection radioButton_EU
        self.radioButton_US = QtGui.QRadioButton(self.frame)
        self.radioButton_US.setGeometry(QtCore.QRect(37, 1, 41, 17))
        self.radioButton_US.setObjectName(_fromUtf8("radioButton_US"))
        self.radioButton_US.clicked.connect(self.on_radioButton_US_clicked) #connection radioButton_US
        self.pushButton10 = QtGui.QPushButton(self.frame)
        self.pushButton10.setGeometry(QtCore.QRect(0, 18, 75, 23))
        self.pushButton10.setToolTip("Create the symbol EU or US"+"\n"
                                     "This button is Independent of the Write button"+"\n"
                                     "If you desire modify the symbol in the cartouche,"+"\n"
                                     "delete the inadequate symbol manualy.")
        self.pushButton10.setEnabled(False)
        self.pushButton10.setObjectName(_fromUtf8("pushButton10"))
        self.pushButton10.clicked.connect(self.on_pushButton10_clicked)     #connection pushButton10
        self.pushButton06 = QtGui.QPushButton(self.centralWidget)
        self.pushButton06.setGeometry(QtCore.QRect(170, 57, 20, 20))
        self.pushButton06.setObjectName(_fromUtf8("pushButton06"))
        self.pushButton06.clicked.connect(self.on_pushButton06_clicked) #connection pushButton06
        self.pushButton07 = QtGui.QPushButton(self.centralWidget)
        self.pushButton07.setGeometry(QtCore.QRect(190, 57, 20, 20))
        self.pushButton07.setObjectName(_fromUtf8("pushButton07"))
        self.pushButton07.clicked.connect(self.on_pushButton07_clicked) #connection pushButton07
        self.pushButton08 = QtGui.QPushButton(self.centralWidget)
        self.pushButton08.setGeometry(QtCore.QRect(170, 137, 20, 20))
        self.pushButton08.setObjectName(_fromUtf8("pushButton08"))
        self.pushButton08.clicked.connect(self.on_pushButton08_clicked) #connection pushButton08
        self.pushButton09 = QtGui.QPushButton(self.centralWidget)
        self.pushButton09.setGeometry(QtCore.QRect(190, 137, 20, 20))
        self.pushButton09.setObjectName(_fromUtf8("pushButton09"))
        self.pushButton09.clicked.connect(self.on_pushButton09_clicked) #connection pushButton09
        self.lineEdit_01 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_01.setGeometry(QtCore.QRect(20, 20, 190, 16))
        font.setPointSize(7)
        self.lineEdit_01.setFont(font)
        self.lineEdit_01.setObjectName(_fromUtf8("lineEdit_01"))
        self.lineEdit_01.setText(DESIGNED_BY)
        self.lineEdit_02 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_02.setGeometry(QtCore.QRect(20, 60, 82, 16))
        self.lineEdit_02.setFont(font)
        self.lineEdit_02.setObjectName(_fromUtf8("lineEdit_02"))
        self.lineEdit_02.setText(CREA_DATE)
        self.lineEdit_02h = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_02h.setGeometry(QtCore.QRect(98, 60, 72, 16))
        self.lineEdit_02h.setFont(font)
        self.lineEdit_02h.setObjectName(_fromUtf8("lineEdit_02h"))
        self.lineEdit_02h.setText(CREA_TIME)
        self.lineEdit_03 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_03.setGeometry(QtCore.QRect(20, 100, 190, 16))
        self.lineEdit_03.setFont(font)
        self.lineEdit_03.setObjectName(_fromUtf8("lineEdit_03"))
        self.lineEdit_03.setText(CHECKED_BY)
        self.lineEdit_04 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_04.setGeometry(QtCore.QRect(20, 140, 82, 16))
        self.lineEdit_04.setFont(font)
        self.lineEdit_04.setObjectName(_fromUtf8("lineEdit_04"))
        self.lineEdit_04.setText(CHEC_DATE)
        self.lineEdit_04h = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_04h.setGeometry(QtCore.QRect(98, 140, 72, 16))
        self.lineEdit_04h.setFont(font)
        self.lineEdit_04h.setObjectName(_fromUtf8("lineEdit_04h"))
        self.lineEdit_04h.setText(CHEC_TIME)
        self.lineEdit_06 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_06.setGeometry(QtCore.QRect(20, 280, 61, 41))
        font.setPointSize(10)
        self.lineEdit_06.setFont(font)
        self.lineEdit_06.setAlignment(QtCore.Qt.AlignCenter)
        self.lineEdit_06.setObjectName(_fromUtf8("lineEdit_06"))
        self.lineEdit_06.setText(SCALE)
        self.lineEdit_07 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_07.setGeometry(QtCore.QRect(100, 280, 101, 41))
        self.lineEdit_07.setFont(font)
        self.lineEdit_07.setAlignment(QtCore.Qt.AlignCenter)
        self.lineEdit_07.setObjectName(_fromUtf8("lineEdit_07"))
        self.lineEdit_07.setText(WEIGHT)
        self.lineEdit_08 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_08.setGeometry(QtCore.QRect(220, 280, 341, 41))
        self.lineEdit_08.setObjectName(_fromUtf8("lineEdit_08"))
        self.lineEdit_08.setText(DRAWING_NUMBER)
        self.lineEdit_09 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_09.setGeometry(QtCore.QRect(570, 280, 81, 41))
        self.lineEdit_09.setObjectName(_fromUtf8("lineEdit_09"))
        self.lineEdit_09.setText(SHEET)
        self.lineEdit_20 = QtGui.QLineEdit(self.centralWidget) # Copyright
        self.lineEdit_20.setGeometry(QtCore.QRect(20, 330, 771, 22))
        self.lineEdit_20.setObjectName(_fromUtf8("lineEdit_20"))
        self.lineEdit_20.setText(COPYRIGHT)
        self.lineEdit_10 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_10.setGeometry(QtCore.QRect(690, 290, 101, 30))
        self.lineEdit_10.setObjectName(_fromUtf8("lineEdit_10"))
        self.lineEdit_10.setText(Note_A)
        self.lineEdit_11 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_11.setGeometry(QtCore.QRect(690, 260, 101, 30))
        self.lineEdit_11.setObjectName(_fromUtf8("lineEdit_11"))
        self.lineEdit_11.setText(Note_B)
        self.lineEdit_12 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_12.setGeometry(QtCore.QRect(690, 230, 101, 30))
        self.lineEdit_12.setObjectName(_fromUtf8("lineEdit_12"))
        self.lineEdit_12.setText(Note_C)
        self.lineEdit_13 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_13.setGeometry(QtCore.QRect(690, 200, 101, 30))
        self.lineEdit_13.setObjectName(_fromUtf8("lineEdit_13"))
        self.lineEdit_13.setText(Note_D)
        self.lineEdit_14 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_14.setGeometry(QtCore.QRect(690, 170, 101, 30))
        self.lineEdit_14.setObjectName(_fromUtf8("lineEdit_14"))
        self.lineEdit_14.setText(Note_E)
        self.lineEdit_15 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_15.setGeometry(QtCore.QRect(690, 140, 101, 30))
        self.lineEdit_15.setObjectName(_fromUtf8("lineEdit_15"))
        self.lineEdit_15.setText(Note_F)
        self.lineEdit_16 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_16.setGeometry(QtCore.QRect(690, 110, 101, 30))
        self.lineEdit_16.setObjectName(_fromUtf8("lineEdit_16"))
        self.lineEdit_16.setText(Note_G)
        self.lineEdit_17 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_17.setGeometry(QtCore.QRect(690, 80, 101, 30))
        self.lineEdit_17.setObjectName(_fromUtf8("lineEdit_17"))
        self.lineEdit_17.setText(Note_H)
        self.lineEdit_18 = QtGui.QLineEdit(self.centralWidget)
        self.lineEdit_18.setGeometry(QtCore.QRect(690, 50, 101, 30))
        self.lineEdit_18.setObjectName(_fromUtf8("lineEdit_18"))
        self.lineEdit_18.setText(Note_I)
        self.lineEdit_page = QtGui.QLineEdit(self.centralWidget)         # nom de page
        self.lineEdit_page.setGeometry(QtCore.QRect(20, 365, 181, 20))
        self.lineEdit_page.setToolTip("Name page to work"+"\n"
                                      "The name of the first page is always named 'Page'"+"\n"
                                      "Select the new page in the Combo view")
        self.lineEdit_page.setObjectName(_fromUtf8("lineEdit_page"))
        self.lineEdit_page.setEnabled(False)
        self.lineEdit_page.setStyleSheet("color: red")
        self.lineEdit_page.setText(PageActive)
        self.lineEdit_page.textChanged.connect(self.on_lineEdit_page_Pressed) #
        self.label_01T = QtGui.QLabel(self.centralWidget)
        self.label_01T.setGeometry(QtCore.QRect(220, 0, 91, 16))
        self.label_01T.setObjectName(_fromUtf8("label_01T"))
        self.textEdit_01 = QtGui.QTextEdit(self.centralWidget)            # Title
        self.textEdit_01.setGeometry(QtCore.QRect(220, 20, 431,55 ))
        font.setPointSize(15)
        font.setBold(True)
        font.setWeight(75)
        self.textEdit_01.setFont(font)
        self.textEdit_01.setObjectName(_fromUtf8("textEdit_01"))
        self.textEdit_01.setText(TITLE)
        self.label_02T = QtGui.QLabel(self.centralWidget)
        self.label_02T.setGeometry(QtCore.QRect(220, 80, 101, 16))
        self.label_02T.setObjectName(_fromUtf8("label_02T"))
        self.textEdit_02 = QtGui.QTextEdit(self.centralWidget)            # DESCRIPTION
        self.textEdit_02.setGeometry(QtCore.QRect(220, 100, 431, 55))
        self.textEdit_02.setObjectName(_fromUtf8("textEdit_02"))
        self.textEdit_02.setText(DESCRIPTION)
        self.label_02bT = QtGui.QLabel(self.centralWidget)
        self.label_02bT.setGeometry(QtCore.QRect(220, 160, 90, 16))
        self.label_02bT.setObjectName(_fromUtf8("label_02bT"))
        self.textEdit_02b = QtGui.QTextEdit(self.centralWidget)            # COMPANY
        self.textEdit_02b.setGeometry(QtCore.QRect(220, 180, 340, 60))
        self.textEdit_02b.setObjectName(_fromUtf8("textEdit_02b"))
        self.textEdit_02b.setText(COMPANY)
        self.label_01 = QtGui.QLabel(self.centralWidget)
        self.label_01.setGeometry(QtCore.QRect(20, 0, 91, 16))
        self.label_01.setObjectName(_fromUtf8("label_01"))
        self.label_02 = QtGui.QLabel(self.centralWidget)
        self.label_02.setGeometry(QtCore.QRect(20, 40, 53, 16))
        self.label_02.setObjectName(_fromUtf8("label_02"))
        self.label_03 = QtGui.QLabel(self.centralWidget)
        self.label_03.setGeometry(QtCore.QRect(20, 80, 101, 16))
        self.label_03.setObjectName(_fromUtf8("label_03"))
        self.label_04 = QtGui.QLabel(self.centralWidget)
        self.label_04.setGeometry(QtCore.QRect(20, 120, 91, 16))
        self.label_04.setObjectName(_fromUtf8("label_04"))
        self.label_06 = QtGui.QLabel(self.centralWidget)
        self.label_06.setGeometry(QtCore.QRect(20, 260, 53, 16))
        self.label_06.setObjectName(_fromUtf8("label_06"))
        self.label_07 = QtGui.QLabel(self.centralWidget)
        self.label_07.setGeometry(QtCore.QRect(100, 260, 101, 16))
        self.label_07.setObjectName(_fromUtf8("label_07"))
        self.label_08 = QtGui.QLabel(self.centralWidget)
        self.label_08.setGeometry(QtCore.QRect(220, 260, 121, 16))
        self.label_08.setObjectName(_fromUtf8("label_08"))
        self.label_09 = QtGui.QLabel(self.centralWidget)
        self.label_09.setGeometry(QtCore.QRect(570, 260, 53, 16))
        self.label_09.setObjectName(_fromUtf8("label_09"))
        self.label_10 = QtGui.QLabel(self.centralWidget)
        self.label_10.setGeometry(QtCore.QRect(670, 290, 16, 33))
        font.setPointSize(12)
        font.setBold(True)
        font.setWeight(75)
        self.label_10.setFont(font)
        self.label_10.setObjectName(_fromUtf8("label_10"))
        self.label_11 = QtGui.QLabel(self.centralWidget)
        self.label_11.setGeometry(QtCore.QRect(670, 260, 16, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_11.setFont(font)
        self.label_11.setObjectName(_fromUtf8("label_11"))
        self.label_12 = QtGui.QLabel(self.centralWidget)
        self.label_12.setGeometry(QtCore.QRect(670, 230, 16, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_12.setFont(font)
        self.label_12.setObjectName(_fromUtf8("label_12"))
        self.label_13 = QtGui.QLabel(self.centralWidget)
        self.label_13.setGeometry(QtCore.QRect(670, 200, 18, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_13.setFont(font)
        self.label_13.setObjectName(_fromUtf8("label_13"))
        self.label_14 = QtGui.QLabel(self.centralWidget)
        self.label_14.setGeometry(QtCore.QRect(670, 170, 15, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_14.setFont(font)
        self.label_14.setObjectName(_fromUtf8("label_14"))
        self.label_15 = QtGui.QLabel(self.centralWidget)
        self.label_15.setGeometry(QtCore.QRect(670, 140, 14, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_15.setFont(font)
        self.label_15.setObjectName(_fromUtf8("label_15"))
        self.label_16 = QtGui.QLabel(self.centralWidget)
        self.label_16.setGeometry(QtCore.QRect(670, 110, 18, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_16.setFont(font)
        self.label_16.setObjectName(_fromUtf8("label_16"))
        self.label_17 = QtGui.QLabel(self.centralWidget)
        self.label_17.setGeometry(QtCore.QRect(670, 80, 18, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_17.setFont(font)
        self.label_17.setObjectName(_fromUtf8("label_17"))
        self.label_18 = QtGui.QLabel(self.centralWidget)
        self.label_18.setGeometry(QtCore.QRect(670, 50, 10, 33))
        font.setBold(True)
        font.setWeight(75)
        self.label_18.setFont(font)
        self.label_18.setObjectName(_fromUtf8("label_18"))
        self.label_19 = QtGui.QLabel(self.centralWidget)
        self.label_19.setGeometry(QtCore.QRect(720, 15, 100, 33))
        self.label_19.setObjectName(_fromUtf8("label_19"))
        self.label_page = QtGui.QLabel(self.centralWidget)
        self.label_page.setGeometry(QtCore.QRect(20, 350, 181, 16))
        self.label_page.setObjectName(_fromUtf8("label_page"))
        self.label_Version = QtGui.QLabel(self.centralWidget)        # Version
        self.label_Version.setGeometry(QtCore.QRect(650, 383, 160, 20))
        self.label_Version.setObjectName(_fromUtf8("label_Version"))
        MainWindow.setCentralWidget(self.centralWidget)
        self.retranslateUi(MainWindow)
        QtCore.QMetaObject.connectSlotsByName(MainWindow)
    def retranslateUi(self, MainWindow):
        MainWindow.setWindowFlags(PySide.QtCore.Qt.WindowStaysOnTopHint) # cette fonction met la fenetre en avant
        MainWindow.setWindowIcon(QtGui.QIcon(self.path + "Macro_CartoucheFC_Full.png")) # change l'icone de la fenetre principale
        MainWindow.setWindowTitle(QtGui.QApplication.translate("MainWindow", __title__ + " ("+__version__+"-"+__date__+") Only for the FC 0.18"))
#        self.pushButton01.setText("Position")
        self.pushButton02.setText("Quit") #Quitter
        self.pushButton03.setText("Memo") #Memo
        self.pushButton04.setText("Clean")#Nettoyer
        self.pushButton05.setText("Write")#Appliquer
        self.pushButton06.setText("D.")
        self.pushButton07.setText("H.")
        self.pushButton08.setText("D.")
        self.pushButton09.setText("H.")
        self.pushButton10.setText("Create Symb.")
        self.label_01.setText("Designed by :")
        self.label_02.setText("Date :")
        self.label_03.setText("Checked by :")
        self.label_04.setText("Date :")
        self.label_06.setText("Scale :")
        self.label_07.setText("Weight (Kg) :")
        self.label_08.setText("Drawing number :")
        self.label_01T.setText("Title :")
        self.label_02T.setText("Description :")
        self.label_02bT.setText("Company :")
        self.label_09.setText("Sheet :")
        self.label_10.setText("A")
        self.label_11.setText("B")
        self.label_12.setText("C")
        self.label_13.setText("D")
        self.label_14.setText("E")
        self.label_15.setText("F")
        self.label_16.setText("G")
        self.label_17.setText("H")
        self.label_18.setText("I")
        self.label_19.setText("Notes")
        self.label_20.setText("Warning")
        self.label_page.setText("Name page to work")
        self.label_Version.setText("Ver: " + str(__version__) + " " +str(__date__))        # Version
        self.groupBox.setTitle("Size :")
        self.radioButton_1.setText("A3 Landscape")
        self.radioButton_2.setText("A3 Portrait")
        self.radioButton_3.setText("A4 Landscape")
        self.radioButton_4.setText("A4 Portrait")
        self.radioButton_EU.setText("EU")
        self.radioButton_US.setText("US")
        self.lineEdit_05.setText("?")
#______________________________________________________________________________________
    # Radio Boutons
    def on_radioButton_A3_clicked(self):  # connect radioButton_A3
        self.pushButton10.setStyleSheet("color: QPalette.Base")          # origin system
        self.pushButton10.setEnabled(True)
        self.lineEdit_05.setStyleSheet("color: QPalette.Base")           # origin system
        self.lineEdit_05.setText("A3")
    def on_radioButton_A4_clicked(self):  # connect radioButton_A4
        self.lineEdit_05.setText("A4")
    # Radio Boutons
    def on_radioButton_EU_clicked(self):    # Bouton /Symbole EU
        global SymbolSwitch
        SymbolSwitch = 1
    def on_radioButton_US_clicked(self):    # Bouton /Symbole US
        global SymbolSwitch
        SymbolSwitch = 0
    def on_pushButton10_clicked(self):      # Bouton /Symbole EU US disposition dans le cartouche
        global SymbolSwitch
        global PageActive
        if self.radioButton_0.isChecked():
            self.label_20.setVisible(True)
            self.label_20.setToolTip("Select the template format")
            self.pushButton10.setStyleSheet("color: red")
            FreeCAD.Console.PrintError("Select one format A3 or A4 for the Symbole" + "\n")
        else:
            self.pushButton10.setStyleSheet("background-color: #FF5B2B")
            self.pushButton10.setText("Wait.")
            FreeCADGui.updateGui()                # rafraichi l'ecran
            if SymbolSwitch == 1:
                if self.radioButton_1.isChecked():
                    symbol_EU(247.5, 263.5, 0.8)  # A3 Landscape
                elif self.radioButton_2.isChecked():
                    symbol_EU(124.55, 386.3, 0.8) # A3 Portrait
                elif self.radioButton_3.isChecked():
                    symbol_EU(158.7, 181.35, 0.6) # A4 Landscape
                elif self.radioButton_4.isChecked():
                    symbol_EU(71.9, 269.0, 0.6)   # A4 Portrait
            else:
                    symbol_US(247.5, 263.5, 0.8)  # A3 Landscape
                    symbol_US(124.55, 386.3, 0.8) # A3 Portrait
                    symbol_US(158.7, 181.35, 0.6) # A4 Landscape
                    symbol_US(71.9, 269.0, 0.6)   # A4 Portrait
            self.pushButton10.setStyleSheet("color: QPalette.Base")# origin system
    def on_lineEdit_page_Pressed(self):   # Name page
        global PageActive
        self.lineEdit_page.setStyleSheet("color: green")
        PageActive = self.lineEdit_page.text()
    def on_pushButton09_clicked(self):    # Bouton /heure document
        self.lineEdit_04h.setText(str(heure()))
    def on_pushButton08_clicked(self):    # Bouton date/ document
        global SymbolSwitch
        if SymbolSwitch==0:
            self.lineEdit_04.setText(str(dateUs()))
        else:
            self.lineEdit_04.setText(str(dateEu()))
    def on_pushButton07_clicked(self):    # Bouton /heure checked
        self.lineEdit_02h.setText(str(heure()))
    def on_pushButton06_clicked(self):    # Bouton date/ checked
        global SymbolSwitch
        if SymbolSwitch==0:
            self.lineEdit_02.setText(str(dateUs()))
        else:
            self.lineEdit_02.setText(str(dateEu()))
    def on_pushButton05_clicked(self):    # Bouton Appliquer
        try:
            global DESIGNED_BY, CREATION_DATE, CREA_DATE  , CREA_TIME, CHECKED_BY, CHECK_DATE
            global CHEC_DATE  , CHEC_TIME    , SIZE       , SCALE    , WEIGHT    ,DRAWING_NUMBER
            global SHEET      , TITLE        , DESCRIPTION, COMPANY  , COPYRIGHT
            global Note_A, Note_B, Note_C, Note_D, Note_E, Note_F, Note_G, Note_H, Note_I
            global ui
            global SymbolSwitch
            global PageActive
            try:
            except Exception:
                self.pushButton05.setStyleSheet("background-color: #FF5B2B")
                self.pushButton05.setText("Wait.")
                DESIGNED_BY = (self.lineEdit_01.text())
                CREATION_DATE = (self.lineEdit_02.text())+" - "+(self.lineEdit_02h.text())
                CHECKED_BY = (self.lineEdit_03.text())
                CHECK_DATE = (self.lineEdit_04.text())+" - "+(self.lineEdit_04h.text())
                SIZE = (self.lineEdit_05.text())
                SCALE = (self.lineEdit_06.text())
                WEIGHT = (self.lineEdit_07.text())
                DRAWING_NUMBER = (self.lineEdit_08.text())
                SHEET = (self.lineEdit_09.text())
                TITLE = (self.textEdit_01.toPlainText())
                DESCRIPTION = (self.textEdit_02.toPlainText())
                COMPANY = (self.textEdit_02b.toPlainText())
                COPYRIGHT = (self.lineEdit_20.text())
                Note_A = (self.lineEdit_10.text())
                Note_B = (self.lineEdit_11.text())
                Note_C = (self.lineEdit_12.text())
                Note_D = (self.lineEdit_13.text())
                Note_E = (self.lineEdit_14.text())
                Note_F = (self.lineEdit_15.text())
                Note_G = (self.lineEdit_16.text())
                Note_H = (self.lineEdit_17.text())
                Note_I = (self.lineEdit_18.text())
                self.pushButton05.setStyleSheet("color: QPalette.Base")           # origin system
                self.pushButton05.setText("Write.")
                try:
                    FreeCAD.getDocument(App.ActiveDocument.Name).getObject(page.Name).EditableTexts = [DESIGNED_BY, CREATION_DATE, CHECKED_BY, CHECK_DATE, SIZE, SCALE, WEIGHT, DRAWING_NUMBER, SHEET, TITLE, DESCRIPTION, COMPANY, COPYRIGHT, Note_A, Note_B, Note_C, Note_D, Note_E, Note_F, Note_G, Note_H, Note_I, ]
#old                    FreeCAD.getDocument(App.ActiveDocument.Name).getObjectsByLabel(PageActive.encode('utf-8'))[0].EditableTexts = [DESIGNED_BY, CREATION_DATE, CHECKED_BY, CHECK_DATE, SIZE, SCALE, WEIGHT, DRAWING_NUMBER, SHEET, TITLE, DESCRIPTION, COMPANY, COPYRIGHT, Note_A, Note_B, Note_C, Note_D, Note_E, Note_F, Note_G, Note_H, Note_I, ]
                    FreeCAD.Console.PrintMessage("Write done to ( " + page.Label + " )" + "\n")
                except Exception:
                    FreeCAD.Console.PrintError("Error write cartouche or verify the selected page ( " + page.Label + " )" + "\n")
            else:
                FreeCAD.Console.PrintError("Error selected page ( " + Page.Label + " )" + "\n")
        except Exception:
           FreeCAD.Console.PrintError("Error or not page " + "\n")
    def on_pushButton04_clicked(self):    # Bouton nettoyer
        self.lineEdit_01.setText("")
        self.lineEdit_02.setText("")
        self.lineEdit_02h.setText("")
        self.lineEdit_03.setText("")
        self.lineEdit_04.setText("")
        self.lineEdit_04h.setText("")
        self.lineEdit_06.setText("")
        self.lineEdit_07.setText("")
        self.lineEdit_08.setText("")
        self.lineEdit_09.setText("")
        self.textEdit_01.setText("")
        self.textEdit_02.setText("")
        self.textEdit_02b.setText("")
        self.lineEdit_20.setText("")
        self.lineEdit_10.setText("")
        self.lineEdit_11.setText("")
        self.lineEdit_12.setText("")
        self.lineEdit_13.setText("")
        self.lineEdit_14.setText("")
        self.lineEdit_15.setText("")
        self.lineEdit_16.setText("")
        self.lineEdit_17.setText("")
        self.lineEdit_18.setText("")
        self.pushButton05.setEnabled(True)
        self.pushButton05.setStyleSheet("background-color: QPalette.Base")     # origin system
        self.groupBox.setEnabled(True)
    def on_pushButton03_clicked(self):    # Bouton Memo
        self.lineEdit_01.setText(MDESIGNED_BY)
        self.lineEdit_02.setText(MCREA_DATE)
        self.lineEdit_02h.setText(MCREA_TIME)
        self.lineEdit_03.setText(MCHECKED_BY)
        self.lineEdit_04.setText(MCHEC_DATE)
        self.lineEdit_04h.setText(MCHEC_TIME)
        self.lineEdit_05.setText("?") #(SIZE)
        self.lineEdit_06.setText(MSCALE)
        self.lineEdit_07.setText(MWEIGHT)
        self.lineEdit_08.setText(MDRAWING_NUMBER)
        self.lineEdit_09.setText(MSHEET)
        self.textEdit_01.setText(MTITLE)
        self.textEdit_02.setText(MDESCRIPTION)
        self.textEdit_02b.setText(MCOMPANY)
        self.lineEdit_20.setText(MCOPYRIGHT)
        self.lineEdit_10.setText(MNote_A)
        self.lineEdit_11.setText(MNote_B)
        self.lineEdit_12.setText(MNote_C)
        self.lineEdit_13.setText(MNote_D)
        self.lineEdit_14.setText(MNote_E)
        self.lineEdit_15.setText(MNote_F)
        self.lineEdit_16.setText(MNote_G)
        self.lineEdit_17.setText(MNote_H)
        self.lineEdit_18.setText(MNote_I)
#        self.lineEdit_page.setText(PageActive)
    def on_pushButton02_clicked(self):    # Bouton Quitter
        App.Console.PrintMessage("End CartoucheFC_Full\r\n")
        self.window.hide()
        FreeCADGui.Selection.removeObserver(s)           # Uninstalls the resident function
        App.Console.PrintMessage("removeObserver"+"\n")
#    def on_pushButton01_clicked(self):    # Bouton appel de Position
#        MainWindow.resize(210, 480)
#        executer()
#        MainWindow.resize(810, 480)
class SelObserver:
    App.Console.PrintMessage("run.."+"\n")
    def setSelection(self, document):
        global PageActive
        global SymbolSwitch
        global ui
        if len(Gui.Selection.getSelection(document)) == 1:
            ff = ui
            ff.lineEdit_page.setStyleSheet("color: QPalette.Base")           # origin system
            ff.pushButton05.setEnabled(True)
            ff.pushButton05.setStyleSheet("background-color: QPalette.Base") # origin system
            ff.groupBox.setEnabled(True)
            if (str(Gui.Selection.getSelection(document)[0].Name[0:4]) == "Page"):
#                PageActive = str(Gui.Selection.getSelection(document)[0].Label.encode('utf-8'))
                PageActive = str(Gui.Selection.getSelection(document)[0].Label)
                try:
                    ff.lineEdit_page.setStyleSheet("color: green")
                    ff.lineEdit_page.setText(unicode(PageActive,'utf-8'))    # convert if accent
                except Exception:
                    ff.lineEdit_page.setText(PageActive)                     # normal
                ####search Symbol
                if "Page" in App.activeDocument().getObjectsByLabel(PageActive)[0].Name:
                    for ii in (App.activeDocument().getObjectsByLabel(PageActive)[0].Group):
                        if (ii.Label == "Symbol_EU"):
                            ff.radioButton_EU.setChecked(True)
                            SymbolSwitch = 1
                            ff.pushButton10.setEnabled(True)
                        elif (ii.Label == "Symbol_US"):
                            ff.radioButton_US.setChecked(True)
                            SymbolSwitch = 0
                memoEntree()                    # entree memo click mouse
                ff.on_pushButton03_clicked()    # Bouton Memo
            else:
                FreeCAD.Console.PrintError("Select a valid Page__________________________" + "\n")
                ff.lineEdit_page.setStyleSheet("color: red")
                ff.lineEdit_page.setText("Select a valid Page")              #
                ff.pushButton05.setEnabled(False)
                ff.pushButton05.setStyleSheet("background-color: red")       # This function gives a color button
                ff.groupBox.setEnabled(False)
                FreeCAD.Console.PrintMessage("                 " + "Name____________Label" + "\n")
                for i in App.ActiveDocument.Objects:
                    if i.Name[0:4] == "Page":
                        name = i.Name + "                 "
                        labe = i.Label+ "                 "
                        FreeCAD.Console.PrintMessage("    Valid Page : " + name[:15] + "," + labe[:25] + "\n")
                FreeCAD.Console.PrintError("_____________________________________________" + "\n")
for obj in FreeCAD.ActiveDocument.Objects:        # deslectionne
        FreeCADGui.Selection.removeSelection(obj)
s=SelObserver()
FreeCADGui.Selection.addObserver(s)               # install the function mode resident
MainWindow = QtGui.QMainWindow()
ui = Ui_MainWindow(MainWindow)
MainWindow.show()
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
Who is online
Users browsing this forum: No registered users and 2 guests
