Making reference to an array of objects
jcdmelo
Post by jcdmelo » Mon Jan 13, 2020 2:04 pm
Hi, everyone,
Thanks for an amazing piece of software! And to the many people who contributed to it!
I am a sort of novice in both FreeCAD and Python, but I have been able to solve my programming chores by experimenting and consulting on this Forum. Thanks again!
But now I am stuck in a situation for which I think I could benefit from this forum and its experts.
I am doing an array of extrusions ('ExtrusionArray') on a body ('Body') attached to a part ('Part'), using an array of sketches ('SketchArray'). These sketches were built from copies of the same sketch, and received proper names ('SketchNameArray'), so that I can refer to them using their internal names.
My code is as follows:
#... (sketches creation and stuff)
for i in range (0, NumExtrusions):
   App.activeDocument().addObject('PartDesign::Body', SketchNameArray[i])
   App.activeDocument().Part.addObject(App.activeDocument().getObject(SketchNameArray[i]))
   App.activeDocument().MYPROBLEM.newObject("PartDesign::Pad", ExtrusionArray[i])
   Gui.activeDocument().hide(SketchNameArray[i])
In 'MYPROBLEM' above resides, well, my problem. How do I refer to a body object, named 'SketchNameArray' which was added to 'Part' in the first line of the for loop?
If one of the sketches is named 'SketchForBody1', then line 1 reads as:
	   App.activeDocument().addObject('PartDesign::Body', 'SketchForBody1')			# Fine!
Then, in the second line, I use the same name to retrieve the body object by using 'App.activeDocument().getObject(SketchNameArray)' which reads as:
	App.activeDocument().Part.addObject((App.activeDocument().SketchForBody1)		# Fine!
Now, in the third line, the problem: I need to refer to the same body object (SketchForBody1), but not as an argument, but as an object. How to do that?
I tried:
	1. App.activeDocument().getObject(SketchNameArray[i]).newObject("PartDesign::Pad", ExtrusionArray[i])
	2. App.activeDocument().App.activeDocument().getObject(SketchNameArray[i]).newObject("PartDesign::Pad", ...
	3. obj = App.activeDocument().addObject('PartDesign::Body', SketchNameArray[i]), followed by
	   App.activeDocument().obj.newObject("PartDesign::Pad", ExtrusionArray[i])
to no avail.
This problem will show up again when I try to refer to one of the items from 'ExtrusionArray'.
Thanks for any suggestions and pointers to documentation or a site.
Julio
microelly2
Re: Making reference to an array of objects
Post by microelly2 » Mon Jan 13, 2020 2:16 pm
if you create two objects with the same name they will have different names
a= App.activeDocument().addObject('PartDesign::Body', 'aname')
b= App.activeDocument().addObject('PartDesign::Body', 'aname')
a.Name is 'aname'
but
b.Name is 'aname001'
To find back to the object you have to store the names of the created objects
yourlistofnames=[a.Name,b.Name]
and tan you get them
App.activeDocument().getObject[yourlistofnames[0]] --> a
App.activeDocument().getObject[yourlistofnames[1]] --> b
openBrain
Post by openBrain » Mon Jan 13, 2020 2:27 pm
Just set it in a variable (eg called 'myBody'). ;) You can do it directly at creation time :
myBody= App.activeDocument().addObject('PartDesign::Body', SketchNameArray[i])
Or recover it later on the same way with the get function. ;)
jcdmelo
Post by jcdmelo » Mon Jan 13, 2020 2:52 pm
Thanks to both microelly2 and openBrain,
Following your hints, I was able to solve MYPROBLEM (not a problem at all, really!)
My code now reads:
... (sketchs creation and stuff)
   Body = App.activeDocument().addObject('PartDesign::Body', SketchNameArray[i])
   App.activeDocument().Part.addObject(Body)
   Extrusion = Body.newObject("PartDesign::Pad", ExtrusionArray[i])
Simple enough, and it works!
Thanks again,
Julio
vocx
Post by vocx » Mon Jan 13, 2020 6:53 pm
Yes, it's a simple as storing the object in a variable and using it later.
Also see the Part_Feature#Scripting to understand the naming.
By the way, I got confused by you naming SketchNameArray. It sounds like it's a Sketch and not a Body.
Who is online
Users browsing this forum: No registered users and 3 guests
