Applying a transformation to a copy of a sketch, not to the original sketch
jcdmelo
Post by jcdmelo » Tue Jan 14, 2020 6:55 pm
Hi, everyone,
I've got one more question: I am trying to make a vertical mirror of a sketch, and then apply a rotation to the copy. My code read as follows:
... (stuff)
# Create a base sketch on plane (X,Y)
Sketch1 = CreateSketch1(Vertices)			# No problem
# Create a copy of the base sketch, mirroring it around the X axis
Sketch2 = CopyMoveandRotateSketch (Sketch1, 0.0, 0.0, 0.0, 0.0, 180.0, 'X') # Fine, I get the mirrored sketch (upside down copy)
# Now, I want to rotate Sketch2 around the Z axis
Sketch3 = CopyMoveandRotateSketch (Sketch2, 0.0, 0.0, 0.0, 0.0, Angle, 'Z') # No good!
# TOO BAD! Sketch3 is not a copy of Sketch2 rotated, but a rotated copy of Sketch1!!!
... (stuff)
My copy routine:
# Copy a sketch with translation and rotation
def CopyMoveandRotateSketch (Sketch, Offx=100.0, Offy=100.0, Cx=0.0, Cy=0.0, Rotation=0.0, Axis='Y'):
   Copy = App.ActiveDocument.copyObject(Sketch, False)
   if Axis == 'X':
      rot = FreeCAD.Rotation(FreeCAD.Vector(1,0,0), Rotation)
   elif Axis == 'Y':
      rot = FreeCAD.Rotation(FreeCAD.Vector(0,1,0), Rotation)
   else:
      rot = FreeCAD.Rotation(FreeCAD.Vector(0,0,1), Rotation)
   center = FreeCAD.Vector(Cx, Cy, 0.0)
   newplace = FreeCAD.Placement(FreeCAD.Vector(Offx, Offy,0), rot, center)
   Copy.Placement = newplace
   return Copy
My question: how to make Sketch2 an independent copy of Sketch1 and then apply the second rotation to Sketch2, not Sketch1? A picture of what happens is attached.
I read that there was a bug with the copyObject method not returning the new object, but the last one on the stack (https://forum.freecadweb.org/viewtopic. ... 0&p=284274), but I am not sure it relates to the problem I am having.
Thanks,
Julio
vocx
Re: Applying a transformation to a copy of a sketch, not to the original sketch
Post by vocx » Tue Jan 14, 2020 7:10 pm
Hi, everyone,
Important information
jcdmelo
Post by jcdmelo » Wed Jan 15, 2020 4:55 pm
Hi, vocx,
Sorry for omitting information about my FreeCAD installation (I went through the important information, and I hope this was my only fault. Please, let me know of any others.)
Here it is:
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Locale: Portuguese/Brazil (pt_BR)
I also checked for information on copyObject on the Forum, and I did not see any clear answer to my question.
And in case anyone wants to play with the code, here it is:
import FreeCAD, FreeCADGui, Part, Sketcher, math
App = FreeCAD
Gui = FreeCADGui
FreeCAD.newDocument("MirrorTest")
# Set sketch vertices
def SetVertices ():
   v1 = FreeCAD.Vector(-30, -100.0, 0.0)
   v2 = FreeCAD.Vector(40, -70.0, 0.0)
   v3 = FreeCAD.Vector(0, 80.0, 0.0)
   v4 = FreeCAD.Vector(-60, -70.0, 0.0)
   Vertices = ([v1,v2,v3,v4])
   return Vertices
# Create original sketch
def DefineSketch (Sketch, Vertices):
      Sketch.addGeometry(Part.LineSegment(Vertices[0],Vertices[1]))
      Sketch.addGeometry(Part.LineSegment(Vertices[1],Vertices[2]))
      Sketch.addConstraint(Sketcher.Constraint('Coincident',0,2,1,1))
      Sketch.addGeometry(Part.LineSegment(Vertices[2],Vertices[3]))
      Sketch.addConstraint(Sketcher.Constraint('Coincident',1,2,2,1))
      Sketch.addGeometry(Part.LineSegment(Vertices[3],Vertices[0]))
      Sketch.addConstraint(Sketcher.Constraint('Coincident',2,2,3,1))
      Sketch.addConstraint(Sketcher.Constraint('Coincident',3,2,0,1))
   if Axis == 'X':
   elif Axis == 'Y':
   else:
   return Copy
def CreateSketch (V):
   Sketch=FreeCAD.ActiveDocument.addObject('Sketcher::SketchObject','Sketch')
   DefineSketch (Sketch, V)
   return Sketch
# Main program
VHB = SetVertices()
Sketch1 = CreateSketch(VHB)
Sketch2 = CopyMoveandRotateSketch (Sketch1, 0.0, 200.0, 0.0, 0.0, 180.0, 'X')
Sketch3 = CopyMoveandRotateSketch (Sketch2, 0.0, 0.0, 0.0, 0.0, -45.0, 'Z')
Sketch1.Label='Sketch1'
Sketch2.Label='Sketch2'
Sketch3.Label='Sketch3'
Gui.SendMsgToActiveView("ViewFit")
Gui.activeDocument().activeView().viewTop()
As I said, I was expecting Sketch3 to be a rotated copy of Sketch2, not of Sketch1.
Thanks,
Julio
vocx
Post by vocx » Thu Jan 16, 2020 3:09 am
What you should do is draw by hand the shapes that you want to obtain. Right now you are saying that you are obtaining wrong shapes. But what do you actually expect?
Maybe you aren't understanding how Placement works.
jcdmelo
Post by jcdmelo » Sun Jan 19, 2020 8:13 pm
Hi, vocx,
Thanks for your hint, but I think you did not understand my question. I read through the Placement docs, and I think the problem is not related to it, but rather to copying objects.
As you can see in the code sent before, what I want is to apply a transformation to a copy (Sketch2) of a base sketch (Sketch1), by using Sketch2 as the argument of a second call to my copying routine. Instead, what I get is a transformed copy of Sketch1. As a matter of fact, in the second call, it works the same if I change the argument to Sketch1, further confirming that it is indeed the sketch that is being passed to the routine. "Picture1" shows what I am getting and "Picture corrected" below shows what I am expecting to accomplish.
To further confirm my belief that this is a copying problem, I went ahead and did as you suggested: I drew by hand the figures shown, starting from Sketch1, copying it to Sketch2, after which I applied a rotation of 180 degrees around the X-axis, copying it to Sketch3 and then applying a rotation of 10 degrees around the Z-axis to obtain what I wanted. All I want is to be able to do this with the Python script I sent.
Thanks,
Julio
Picture corrected.png (116.85 KiB) Viewed 186 times
vocx
Post by vocx » Tue Jan 21, 2020 7:12 am
Hi, vocx,
Thanks for your hint, but I think you did not understand my question....
Yes, and I think you didn't explain it properly.
Chris_G
Post by Chris_G » Tue Jan 21, 2020 8:37 am
In your CopyMoveandRotateSketch function, you do this :
It means that you are replacing Copy's placement by a new one
Sketch2.Placement
# returns : Placement [Pos=(0,0,0), Yaw-Pitch-Roll=(0,0,180)]
Sketch3 = CopyMoveandRotateSketch (Sketch2, 0.0, 0.0, 0.0, 0.0, 45, 'Z')
Sketch3.Placement
# returns : Placement [Pos=(0,0,0), Yaw-Pitch-Roll=(45,0,0)]
But you want your function to have a cumulative effect, so, in your CopyMoveandRotateSketch function, the placement should be :
Copy.Placement.Matrix = Sketch.Placement.Matrix.multiply(newplace.Matrix)
jcdmelo
Post by jcdmelo » Wed Jan 22, 2020 5:32 pm
Thanks, Chris and vocx,
That solved my question. I don't know if it is a version issue or just a different syntax, but the actual statement is slightly different from what you suggested. I have yet to grasp a lot of FreeCAD concepts, and Python, and OOP, ...
I used:
   Copy.Placement = Sketch.Placement.multiply(newplace)
instead of:
Julio
Who is online
Users browsing this forum: No registered users and 3 guests
