memory leak in script?
r31415
Post by r31415 » Fri Jan 17, 2020 4:33 pm
I've created a script, which loads STP-files and converts them to SVGs. Unfortunately, this script:
  • eats up more and more memory with every STP-file I load/convert, up to several GB
  • on exit, shows an error-message for each loaded STP-file:
    Exception while processing file: FILE1.stp [Cannot load Gui module in console application.]
    Exception while processing file: FILE2.stp [Cannot load Gui module in console application.]
This is my first FreeCAD-script, so maybe I'm doing something wrong.
So: Can you tell me what I'm doing wrong? Or is this a bug in FreeCAD?
Here's the script:
#!/usr/bin/env FreeCADCmd
# Convert 3D-files to SVG (in the default view) via FreeCAD
# :Author: Roland Freikamp
# :Version: 2020-01-17
import os
import sys
import FreeCAD
import Part
import importSVG
print("== Convert 3D-files to SVG")
for filename in sys.argv[2:]:
    svgfile = os.path.splitext(filename)[0].replace(" ","_") + ".svg"
    print("-- %s -> %s" % (filename, svgfile))
    if not os.path.exists(filename):
        print("ERROR: '%s' does not exist." % filename)
        continue
    if os.path.exists(svgfile):
        print("ERROR: SVG-file '%s' already exists." % svgfile)
        continue
    doc = FreeCAD.newDocument("doc")
    p = Part.read(filename)
    f = doc.addObject("Part::Feature", "obj")
    f.Shape = p
    doc.recompute()
    importSVG.export([doc.getObject("obj")], svgfile)
    doc.removeObject("obj")
    FreeCAD.closeDocument("doc")
DeepSOIC
Re: memory leak in script?
Post by DeepSOIC » Fri Jan 17, 2020 5:20 pm
Seems good to me, nothing obvious to cause a memory leak.
What is your FreeCAD version, btw? (see IMPORTANT: Please read first before asking for help for how to post it)
openBrain
Post by openBrain » Fri Jan 17, 2020 6:08 pm
I think your whole export processing could be reduced to something like:
importSVG.export(Import.open(filename), svgfile)
You have to import the 'Import' module, but no need to create a document and/or populate it with object. ;)
Site Admin
Post by wmayer » Sat Jan 18, 2020 10:56 am
This is because when passing several file names to the executable then it tries to handle them one by one. This means the application first runs your script which internally already handles the further arguments and after it's finished it tries to handle the STEP file.
Now there is a mistake in how the STEP file format is added because it's registered for the ImportGui module but for a GUI-less application this makes not much sense. So, this is something that should still be improved in FreeCAD.
Nevertheless in order to get rid of this issue just add quit() at the end of your script because then the application terminates after having executed it.
Your script looks fine but under the hood a lot of things happen. If there is a memory leak somewhere then most likely when loading the STEP or when converting it. You can adjust the script to check if one of the two is the culprit:
  • Only load STEP files without converting them. If the RAM usage increases constantly then this is the problem.
  • Only load one STEP a single time and convert it several times. If the RAM usage increases constantly then this is the problem.
Site Admin
Post by wmayer » Sat Jan 18, 2020 2:33 pm
This git commit 120b69c74f7 fixes the file type issue. So, when using the command line version it won't try to load the GUI module any more.
r31415
Post by r31415 » Tue Jan 21, 2020 3:28 pm
Thanks for your answers.
  • memory leak:
    importSVG.export(...)
    eats up the memory. Without this command, memory usage is ok.
    Loading only one stp-file, and running importSVG.export(...) in a loop, also eats up memory.
    It looks like importSVG.export never frees the memory again.
    Simplified demo-script (but beware: use a memory monitor and be ready to hit Ctrl-C to abort the script before it eats up too much memory!):
    import sys
    import FreeCAD
    import Part
    import importSVG
    import Import
    filename = sys.argv[2]
    f.Shape = p
    doc.recompute()
    obj = doc.getObject("obj")
    for i in range(0,10):
        print("--", i)
        importSVG.export([obj], "%d.svg" % i)
    quit()
  • error-messages on exit:
    Adding quit() or sys.exit(0) removes the error-messages at the end.
  • simplified script:
    Unfortunately not; I've tried this, but this results in the error:
    Exception while processing file: /home/user/convert_stp_to_svg.py ['tuple' object has no attribute 'isDerivedFrom']
    Probably this works for converting between 3D-formats, but not for exporting to 2D.
  • FreeCAD-version: 0.18.3
    Details:
    OS: NixOS 19.09
    Version: 0.18.Unknown
    Python version: 3.7.5
    Qt version: 5.12.3
    Locale: English/Denmark (en_DK)
    I could try this with 0.18.4 or 0.19_pre or the latest commit, if this would help.
Who is online
Users browsing this forum: No registered users and 3 guests
