[Question] Mouse Over Dockwidget
HakanSeven12
Post by HakanSeven12 »
I'm working on autocad like autohide. How to detect mouse over combo or other dock widgets?
Last edited by HakanSeven12 on Sat Mar 28, 2020 10:18 am, edited 4 times in total.
HakanSeven12
Re: [Question] Mouse Over Dockwidget
image added
mario52
Post by mario52 »
HakanSeven12
mario52 wrote: Sat Mar 28, 2020 10:43 am hi
https://doc.qt.io/qt-5/qwidget.html#underMouse
mario
If I create a dock widget I can use it. Also I can use enterEvent and leaveEvent. But when I get combo view how can I add it to event?
openBrain
Post by openBrain »
You need to use installEventFilter() on the dock widget. ;)
HakanSeven12
openBrain wrote: Sat Mar 28, 2020 12:16 pm You need to use installEventFilter() on the dock widget. ;)
tried something but dont work :)
from PySide2 import QtCore, QtGui, QtWidgets
mv = FreeCADGui.getMainWindow()
combo = mv.findChild(QtWidgets.QDockWidget, "Combo View")
class autoHide(QtWidgets.QWidget):
    def __init__(self):
        QtWidgets.QWidget.__init__(self)
        combo.installEventFilter(self)
    def eventFilter(self, source, event):
        if source is combo:
            if event.type() == event.Enter:
                print ("Mouse Entered")
                self.target.setFeatures = self.oldFeatures
                return True
            elif event.type() == event.Leave:
                print("Mouse Left")
                return True
            return super(autoHide, self).eventFilter(source, event)
autoHide().show()
openBrain
Post by openBrain »
The main problem IMO is that your class instance is initialized without parent and thus I think is automatically destroyed :
from PySide import QtCore, QtGui
class autoHide(QtCore.QObject):
    def __init__(self):
        self.target = mv.findChild(QtGui.QDockWidget, "Combo View")
        super(autoHide, self).__init__(self.target)
        self.target.installEventFilter(self)
        if source is self.target:
                return True
                print("Mouse Left")
                return True
autoHide()
HakanSeven12
openBrain wrote: Sat Mar 28, 2020 1:22 pm The main problem IMO is that your class instance is initialized without parent and thus I think is automatically destroyed
thanks :D Its work
HakanSeven12
Result
Post by Kunda1 »
HakanSeven12 wrote: Sat Mar 28, 2020 1:43 pm Result
Nice!
Can something be done about the navicube jumping around ?
