Is there a way to test if the parent of a Part::FeaturePython is a Boolean and if yes, how to test if is the Base or Tool part of the Boolean?
If I look at the inList for the Part::FeaturePython I just see the parent of the Boolean (when the immediate parent is a Boolean).
I note that when scanning a document there appears to be a PartGui::ViewProviderPython object following each Part::FeaturePython object.
Is this a correct conclusion and if yes does it give any clues as to whether the parent is a Boolean?
Thanks
[Is this a BUG] Test if Parent of Part::FeaturePython is a Boolean
Re: Test if Parent of Part::FeaturePython is a Boolean
Okay I have resorted to the following code, but see sure there must be a better and more efficient way
def indexBoolean(list,ln) :
#print('Length : '+str(ln))
if ln > 3 :
#print(range(ln-3))
for r in range(ln-2) :
t = list[r].TypeId
#print(t)
if t == 'Part::Cut' or t == 'Part::Fuse' or t == 'Part::Common' :
return r
def __init__(self, obj):
'''Init'''
if hasattr(obj,'InList') :
for j in obj.InList :
if hasattr(j,'OutList') :
ln = len(j.OutList)
r = indexBoolean(j.OutList,ln)
#print('index : '+str(r))
if r >= 0 :
if (ln - r) >= 2 :
#print('Tool : '+obj.Label)
return # Okay part of Boolean Let Placement default to 0
obj.setEditorMode('Placement',2)
Re: [Is this a BUG] Test if Parent of Part::FeaturePython is a Boolean
Wondering if this is made harder as a result of a bug?
If an Object is part of a Boolean, should its parent i.e. its InList be the boolean?
What I observe is that is that its InList is the parent of the boolean, so is this a bug?
Impossible to investigate without having at least the sample file you're working on.
Maybe you can find some info in this thread.
