Is there a way to restore a Part object and its children using the dumpContent / restoreContent methods?
As example, open the attached test.fcstd file and try:
part_bin = FreeCAD.ActiveDocument.Part.dumpContent()
new_doc = FreeCAD.newDocument()
new_part = new_doc.addObject('App::Part','RESTORED_PART')
new_part.restoreContent( part_bin )
From the documentation of "dumpContent" function:Lost link to 'Body' while loading, maybe an object was not loaded correctly
FreeCAD.ActiveDocument.Part.dumpContent.__doc__
The docstring of the "restoreContent" function:'Dumps the content of the object, both the XML representation as well as the additional datafiles \nrequired, into a byte representation. It will be returned as byte array.\ndumpContent() -- returns a byte array with full content\ndumpContent(Compression=1-9) -- Sets the data compression from 0 (no) to 9 (max)\n
FreeCAD.ActiveDocument.Part.restoreContent.__doc__
What I want to achieve is to transfer some models inside the document through network and recreate them on another file (editable, parametric and all that), as a part of a version-control system.'Restore the content of the object from a byte representation as stored by "dumpContent".\nIt could be restored from any python object implementing the buffer protocol.\nrestoreContent(buffer) -- restores from the given byte array\n '
I only found some unconnected info about this, and this possibly related thread from which I have extracted the example shown.
Thank you
Edited: forgot to add my FC info.
OS: Ubuntu 20.04.1 LTS
Version: 0.18.4.
Python version: 3.8.2
Qt version: 5.12.8
Locale: Spanish/Spain (es_ES)
