How to judge the type of model?
freecadlzh
Post by freecadlzh »
In Freecad, In part workbench ,use cube tools added a cube model named "Box", Now get the model and get the type using code:
>>> ooo =FreeCAD.ActiveDocument.getObject("Box")
>>> type(ooo)
<class 'PrimitivePy'>
Now I wanted to judge the type of the model in python script:
if type(ooo) == PrimitivePy:
    print("1")
When the script runs goes errors:
NameError: name 'PrimitivePy' is not defined
So I changed the code as below:
if type(ooo) == "PrimitivePy":
    print("1")
When script runs, no errors, but "print("1")" not runs.
So my problem is how to judge the type of the Cube model in "if" code?
Need helps , Thanks a lot.
openBrain
Re: How to judge the type of model?
Post by openBrain »
I don't know why it's better to use this rather than ooo.TypeId, but you can do this with :
if "'PrimitivePy'" in str(type(ooo)):
freecadlzh
openBrain wrote: Wed Dec 02, 2020 12:38 pm I don't know why it's better to use this rather than ooo.TypeId, but you can do this with :
Good! It is a way! Follow yours code , it can runs and print("1").
Any other way to code this ?
Because :
>>> type(1)
<class 'int'>
>>> if type(1) == int:
...     print("1")
1
So is there any other way to code?
openBrain
Post by openBrain »
freecadlzh wrote: Wed Dec 02, 2020 1:06 pm Any other way to code this ?
What are you trying to code ? Do you want to identify only boxes ? Or any Part primitive ? Or any 3D object ?
