I agree that the profile is typically perpendicular to the path (the tool). But how do you propose to handle the position and rotation of the profile relative to the path if there are multiple paths and only one profile?
Arch Structure with Base and Tool
Re: Arch Structure with Base and Tool
The profile Sketch or Face would stay at the origin at all times.
During the recompute of an Arch Structure which uses that profile, a temporary copy of the profile's shape would be created, placed and oriented perpendicular to the path. The copy would only exist as a python/c++ Shape object, not as an actual object in the document tree.
OK, one problem by one problem
I have studied ArchWall.getExtrusionData() and tweak some features there. The ArchWall originally does not works very well to exportIFC if it is base on a sketch.
https://forum.freecadweb.org/viewtopic.php?f=23&t=38527
https://forum.freecadweb.org/viewtopic.php?f=23&t=39060
https://forum.freecadweb.org/viewtopic. ... 36#p355457
So you may like to try try exportIFC of an ArchStructure base on a multiple close loop wires Sketch.
You may like to submit a PR ? Or ping @Yorik to have a look first ?
I guess so you can have several close loop to extrude altogether, like a bunch of columns...alafr wrote: ↑Sun Feb 09, 2020 11:39 am ...It uses obj.Base which is the Sketch, and not shi, which is the face previously created.Code: Select all
675 shi = obj.Tool.Shape.copy().makePipe(obj.Base.Shape.copy())
But what I don't understand is why this line is in a for loop: if len(sh) > 1, then the same extrusion will be repeated multiple times: it doesn't make sense...
I have some finding as you doalafr wrote: ↑Sun Feb 09, 2020 11:39 am If I replace the line 675 with:it works with the Structure Sketch and Tool.FCStd file. However I will have to do more tests with various placements/sketch orientations to check that it doesn't introduce new buggy behaviours.Code: Select all
675 shi = obj.Tool.Shape.copy().makePipe(shi)
Re: Feature requests for Arch Structure
Yes, as I explained in last post what i am attempting to do an big complex ArchWall base on complex Sketchalafr wrote: ↑Sun Feb 09, 2020 11:56 am It would make it possible to build a complex model with many Structure objects with one single master Sketch. Each Structure element would use one of the Sketch's edges. Currently the workaround that I found is to create a new Sketch for each Structure object, and add the edge from the master Sketch in it as an "external geometry".
EDIT
Seem there are 2 options of :-
- same profile like a rectangle + 1 Complex masterSketch as Tool --> 1 complex ArchStructure
( same profile automatically extruded along each edges in masterSketch) - 1 profile + Selected Edge at a Complex masterSketch as Tool --> 1 ArchStructure for an edge
( So you need n number of ArchStructure for n number of wires in a complex MasterSketch)
You got it right - do not delete edges in Sketch. Also, do not change any edge into construction mode
But somebody and I have argued the typical topological problem should not happened in a Sketch. Every edges are created by user, not generating by any internal shape building mechanism.
With aid of a few peoples most importantly @abdullah (who I have no idea why have not been around since a few months ago suddenly without any sign), I can trace every and each edges (with its Tag) so you build on an edge in a Sketch, it won't change even when you delete an edge or turn some of them into construction edge.
Arch Structures based on a tool aren't exported correctly to IFC (whether Base is a Sketch or a Face, with or without holes): If I check "Force export as Brep" in the preferences it exports correctly but the curved faces are triangulated.
This could work, but would be quite restrictive. In a typical steel structure the same profiles can occur rotated and/or mirrored. And in certain cases (corner columns) the position of the profile relative to the path may require X and Y offsets.alafr wrote: ↑Sun Feb 09, 2020 3:41 pmThe profile Sketch or Face would stay at the origin at all times.
Maybe you can help posting in the IFC sub-forum, or simply ping @Bernd here ?
He is working on IFCexport, @Yorik is not alone there
This would still be possible with the current workflow. The new option shouldn't change anything when set to False (by default).
Additional properties (ProfileOffset, ProfileRotation) could also be added to make the new option useful in more cases.
Regarding ifc export, our exporter currently only exports straight extrusions (profile + extrusion vector). we should actually implement swept profile support for those structures with a tool object.e
Personally, I've never used this. What I would do is create complicated geometrical shapes using the PartDesign Workbench.
Once you have your finished Body, then you can use the Arch Structure command on that Body, to sort of "encapsulate" it. That is, the Arch Structure command can work in two ways: it can create the solid geometry, or it can just convert an existing shape into a structural element. So, for your case, I would use the second method. Use the path and the sketch as you would in PartDesign, and the produce a pipe; then turn the entire Body into a structure.
