SirDancealot wrote: ↑Thu Jul 09, 2020 2:57 pm
Would you be so kind and tell us, how did you get this good at this expertise, my good sir?
You have to do your documentation homework and then put in the hours. There is no substitute.
I started with Version 0.13, graduated to V0.17 PartDesign, and took my masters in
V0.19 Assembly4. A couple of hours each day keeps me current with the software development
so I do not forget what I've learned. We greybeards require constant refreshing.
I turned the corner on the steep learning curve when I became comfortable with placement properties
and advanced when I learned how to avoid attaching sketches to feature faces, edges, or vertices.
Models break much less often and you gain the advantage of parametric behavior which is essential
if you ever have to make changes. That is the key to CAD productivity IMHO since engineers are notorious for
making changes.
Focus on one workbench and stick with it. Do not mix them unless you absolutely have to.
Remember that you only have to learn about 20% of the tools to complete 80% of the work in mechanical design.
I use PartDesign for 90+% of my work and a several workbench tools from Draft (Arrays), Part (Mirror, Helix primitive),
and occasionally the Gear workbench.
I use Assembly4 since it nicely supports top-down design and animation in a simple, logically straight forward manner
with no unnecessary frills. It also provides a nicely integrated way of adding standard fasteners.
Start with
simple bodies (100's) with few features and graduate to more complex bodies since they are no more than a collection
of simple features. Then, try simple assemblies using master sketches. If you can create these then you can do more
complex assemblies since they are no more than a collection of sub-assemblies. Finally, learn how to articulate
the moving parts since you cannot design an assembly without verifying that nothing collides over its range of motion.
Expressions and variables are good to learn early on because they facilitate robust parametric modelling.
I rarely use the spreadsheet workbench but rather find that the Assembly4 variable property panel (or the DynamicData workbench)
is a more than adequate substitute which is easier to use in practice.
Would you consider making a step by step instruction manual for this, if I dare??
No. I prefer to show by examples some of the intermediate to advanced modelling concepts. There are several in the Users Showcase and the Assembly4 forum. You can learn a lot by step-by-step review of someone else's model tree. IMO there is more than sufficient documentation
and tutorials for beginners.
