ArchWall Creation Problem on Sketch
paullee
Post by paullee » Wed May 10, 2017 7:31 pm
Hi, I have created a Sketch and want to build ArchWall upon it. I find I am stuck in following situation.
1. I try build ArchWall upon it, it return the Sketch has invalid shape - but i don't know what is wrong, see below.
2. I have a habit of upgrading the Sketch into Dwire, so I do it again though the ArchWall result would be different for a Sketch and Dwire. Now ArchWall could be created without problem upon the said Dwire (which still depending on the same underlying Sketch) .
3. I intend to do an ArchWall based on the Sketch (1 above) so that I get an perimeter wall. If the ArchWall is built upon the Dwire (face on), it become a volume.
Am i missing something?
Screenshot from 2017-05-11 03-08-49.png (180.43 KiB) Viewed 2056 times
Screenshot from 2017-05-11 03-09-17.png (193.23 KiB) Viewed 2056 times
OS: Linux
Version: 0.17.11009 (Git)
Build type: Unknown
Hash: 77386684fb76c0d91ea05cc6a0e005d5d8441d21
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Query_ ArchWall_ on Sketch_ has invalid shape.fcstd
(16.46 KiB) Downloaded 52 times
yorik
Site Admin
Re: ArchWall Creation Problem on Sketch
Post by yorik » Thu May 11, 2017 8:03 pm
The result of the wall depends if the base shape is a Wire or a Face. If it's a wire, it gets first "thickened" to the given wall thickness, then extruded by the wall height value. If it is a face, it is understood that you are already giving it the footprint, and it is simply extruded upwards. When you have a draft wire, you can set its "MakeFace" property to false to prevent it from forming a face and make it behave as a wire instead.
paullee
Post by paullee » Fri May 12, 2017 11:03 am
yorik wrote:The result of the wall depends if the base shape is a Wire or a Face. If it's a wire, it gets first "thickened" to the given wall thickness, then extruded by the wall height value. If it is a face, it is understood that you are already giving it the footprint, and it is simply extruded upwards. When you have a draft wire, you can set its "MakeFace" property to false to prevent it from forming a face and make it behave as a wire instead.
Thanks! I understand it would be a solid volume if it is a Wire w/ face.
The current problem is, whether i use the underlying sketch, or the DWire w/ face Off, FC report it is an invalid shape.
I can't figure out what am i missing? Any topology not valid for ArchWall?
yorik
Site Admin
Post by yorik » Mon May 15, 2017 8:11 pm
There is apparently something in that sketch that the DraftGeomUtils.offsetWire function doesn't like (it fails to produce a correct offset). I must think to switch to the new Part offset2D code, that will likely work better
triplus
Post by triplus » Wed Nov 29, 2017 7:19 pm
paullee
Post by paullee » Thu Nov 30, 2017 12:22 am
Reference:
https://forum.freecadweb.org/viewtopic. ... 80#p201903
Thanks for testing that - will check that again.
The following same sketch is tested on 2 AppImages, 1 ok to create ArchWall, 1 failed (sometime 1 git nothing, sometime a few wall out of all edges).
The sketch had been ok to create Arch Wall for a nos of git, suddenly on recent git, I try to create a copy of wall again I found it become not successful.
p.s.
As the problem is more related to this thread, i try to continue here.
Broken on Recent git - FreeCAD-0.17.git201711241625.glibc-x86_64.AppImage
Screenshot from 2017-11-30 08-12-05.png (339.08 KiB) Viewed 1765 times
OK on Earlier git - FreeCAD-0.17.git201709161157.glibc2.17-x86_64.AppImage
Screenshot from 2017-11-30 08-11-17.png (345.18 KiB) Viewed 1765 times
Test _ Arch Wall _ on Sketch_ bug question.fcstd
(5.5 KiB) Downloaded 43 times
triplus
Post by triplus » Fri Dec 01, 2017 4:41 pm
I can confirm the Arch Wall command won't create the expected result on your sketch. When using FreeCAD 0.17 Daily. But if i try to delete something in your Sketch i get pop-ups saying something about issues with constraints. Therefore i assumed this sketch is also borked in some way. A created a new sketch and "traced" the 2D geometry in your sketch "by hand". This time Arch Wall command created the expected result:
Therefore my advice would be create a new file and redo the sketch. Try Arch Wall command on that new sketch after.
paullee
Post by paullee » Fri Dec 01, 2017 7:02 pm
This is the problem - w/o knowing if and what may be the problem. Chrisb once has some comment on my using of sketch constraints but find it in order later https://forum.freecadweb.org/viewtopic.php?f=22&t=25071
I am aware of the pop up, though i suspect it is inherent mechanism of sketcher - deleting elements leaving some constraints to remaining relevant edges / points and 'duplicating' - wild-guessing, i have no knowledge to dig it further.
I am experimenting using sketches, linked each to the other by expression, to draw layout of wall and build on top of it. Redrawing still needs constraints I put it probably and defeat the purpose ....
Anyway, if a git version which is stable and always build walls successfully, is hopefully available, I may stick to it.
triplus
Post by triplus » Sat Dec 02, 2017 12:52 am
Could be there is a bug involved (or not). As this is the first time i experienced this particular pop-up i have no clue on what i would need to do to produce one. If you ever figure that please provide a step-by-step instructions on how to do it.
You can stick with any version of AppImage to achieve that. As each one contains FreeCAD code base, important libraries like OCC... The same version therefore in general will/should always produce the same results.
paullee
Post by paullee » Sun Dec 03, 2017 6:12 pm
Thanks again taking the time, I will see if I can single out the pop-up errors and find other examples of sketch failing to build Arch Wall and hope it helps.
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], tectone, tonyaimer and 13 guests
