Log: Connected to spacenav daemon
Edit:
Linuxbox restarted and .Xauthority copy removed from /root (just in case) - it's still the same.
FreeCAD connects to spacenavd, but no buttons and doesn't work.
spacenavd configuration tool (spnavcfg) reports daemon is not running! So FreeCAD reports connection even when the daemon is not running (TBC)?
Started spacenavd with:
systemctl start spacenavd
$ systemctl status spacenavd
● spacenavd.service - 3Dconnexion Input Devices Userspace Driver
Loaded: loaded (/usr/lib/systemd/system/spacenavd.service; disabled; vendor preset: dis>
Active: active (running) since Sat 2018-07-28 13:46:25 IST; 8s ago
Process: 4724 ExecStart=/usr/bin/spacenavd (code=exited, status=0/SUCCESS)
Main PID: 4726 (spacenavd)
Tasks: 1 (limit: 4915)
Memory: 344.0K
CGroup: /system.slice/spacenavd.service
└─4726 /usr/bin/spacenavd
lip 28 13:46:25 fedora systemd[1]: Starting 3Dconnexion Input Devices Userspace Driver...
lip 28 13:46:25 fedora systemd[1]: Started 3Dconnexion Input Devices Userspace Driver.
