Loft preview works but disappears when applied
crimmy68
Post by crimmy68 » Tue Jan 14, 2020 11:51 am
I have 3 fully constrained sketches.
When I try to execute an additive loft I can see the part being lofted as I expect to happen in the preview but when I click on the final "OK" button
The loft is created in the hiarchy (and visable) but the actual part just isn't there.
I'll upload the FCStd file
The are 3 sketches visable just try to loft these sketches to see what I mean
Anyone has an idea what might be wrong here ?
Thanks in advance
Best regards crimmy68
loft issue.FCStd
(51.25 KiB) Downloaded 7 times
Roy_043
Re: Loft preview works but disappears when applied
Post by Roy_043 » Tue Jan 14, 2020 1:40 pm
There has to be an overlap between the additive loft and the plate with the ventilation hole.
crimmy68
Post by crimmy68 » Tue Jan 14, 2020 5:12 pm
Thanks for your reply :D
I’ll test this asap
vocx
Post by vocx » Tue Jan 14, 2020 6:39 pm
You are not allowed discontinuous or floating solids inside a PartDesign Body.
crimmy68
Post by crimmy68 » Thu Jan 16, 2020 12:14 pm
This works indeed.
Thanks for the fast replies :-)
Best regards Crimmy68
Post by chrisb » Fri Jan 17, 2020 1:19 am
... or floating solids inside a PartDesign Body.
Could you please explain what you mean by "floating solid"?
vocx
Post by vocx » Fri Jan 17, 2020 1:28 am
It's in the PartDesign Body description. Discontiguous solids inside the same Body are not permitted. If you have two solids that don't touch each other, you could say that one is "floating" with respect to the other.
Who is online
Users browsing this forum: bzowk and 8 guests
