How do I find the 16 needed constraints
keithsloan52
Post by keithsloan52 » Tue Jan 14, 2020 7:47 pm
See attached file
Hide_Door2.FCStd
(7.1 KiB) Downloaded 15 times
drmacro
Re: How do I find the 16 needed constraints
Post by drmacro » Tue Jan 14, 2020 7:57 pm
The number/word "16 degrees" is clickable.
When you click on it, the objects that are not constrained are highlighted in green.
openBrain
Post by openBrain » Tue Jan 14, 2020 8:35 pm
First, there are a lot of 16-constraint sets that work. Also there a lot (much more) that don't work. :)
Then FC by itself will not make it magically happen for you. This is human cleverness to find which set is correct and fits what you want.
You need to learn and practice to gain skill/knowledge/know-how. ;)
However having good geometry knowledge ease things. Reading chrisb's tutorial is also a good entry point to understand DoF concept (as applied in solver of sketcher).
bejant
Post by bejant » Tue Jan 14, 2020 8:56 pm
The endpoints of the upper 2 inner rectangles are missing some Coincident Constraints:
keithsloan52
Post by keithsloan52 » Wed Jan 15, 2020 8:19 pm
Okay I got down to seven, but now seem to be stuck
Hide_Door2.FCStd
(7.04 KiB) Downloaded 11 times
drmacro
Post by drmacro » Wed Jan 15, 2020 8:54 pm
The reason you are stuck is many of the end points of your geometry were not coincident and thus were not constrained as yet.
I would recommend you use the rectangle tool to draw rectangles, it will produce rectangles with coincident corners.
I have attached my take on what you are attempting, just for reference.
Hide_Door2-mac.FCStd
(7.5 KiB) Downloaded 6 times
openBrain
Post by openBrain » Wed Jan 15, 2020 10:00 pm
You can use the Sketcher ValidateSketch tool to find open vertices and missing coincidences. ;)
keithsloan52
Post by keithsloan52 » Wed Jan 15, 2020 10:36 pm
Thanks
keithsloan52
Post by keithsloan52 » Thu Jan 16, 2020 6:11 pm
Okay I am now trying to make two circular holes in sketch001.
Hide_Door2-A.FCStd
(26.76 KiB) Downloaded 11 times
They seem to display as construction lines and I try toggle them.
Or do I need to drill them separately?
Thanks
drmacro
Post by drmacro » Thu Jan 16, 2020 6:27 pm
When the lines of a sketch are blue, that means they are construction geometry. Choose
to toggle from/to construction mode.
Hide_Door2-A-mac.FCStd
(29.33 KiB) Downloaded 2 times
Who is online
Users browsing this forum: Bing [Bot], FredB and 12 guests
