How to hide features from A2Plus?
leoheck
Post by leoheck » Wed Jan 15, 2020 12:11 pm
I use A2Plus a lot, it is essential for me.
Before, I've asked for help to create a 3D path. As you can see here in this post 3d wires. To achieve that, I'm using the Section feature.
The issue now is that the Section feature is being imported with A2Plus even when it is hidden.
So, I would like to know how can I hide this extra feature from the A2Plus plugin?
leoheck
Re: How to hide features from A2Plus?
Post by leoheck » Wed Jan 15, 2020 12:47 pm
I can improve the extra feature placement moving it far from my main body but I would like to remove it when using A2Plus if possible.
kbwbe
Post by kbwbe » Wed Jan 15, 2020 9:31 pm
Please post a small sample file for examining this problem.
KBWBE
latest release: v0.4.42b, installable via FreeCAD's addon manager
leoheck
Post by leoheck » Wed Jan 15, 2020 11:24 pm
@kbwbe, sure!
I have this cheminey.FCStd file with the Body and the Section_3d_path that I use only to create a path that I can use to Sweep another Sketch using Part Design Workdbench. The Section_3d_path is hidden by default.
cheminey.FCStd
(64.95 KiB) Downloaded 7 times
I am importing the cheminey.FCStd in the assembly.FCStd file with A2Plus plugin. But A2Plugin is importing all features from the cheminey file including the Section_3d_path which should be hidden/avoided.
assembly.FCStd
(20.74 KiB) Downloaded 6 times
I forgot to mention that I am using A2Plus 0.4.39a.
The original model is this:
It is being imported like this:
kbwbe
Post by kbwbe » Thu Jan 16, 2020 10:47 am
Activate the A2p preference "do not import invisible Shapes..." and the Section_3d_path is gone during import.
At weekend, i will try to do an update and filter out these elements generally as they are making no sense for an import.
KBWBE
leoheck
Post by leoheck » Thu Jan 16, 2020 2:53 pm
Thanks kbwbe.
leoheck
Post by leoheck » Thu Jan 16, 2020 5:21 pm
@kbwbe, where I can find that preference?
leoheck
Post by leoheck » Thu Jan 16, 2020 5:51 pm
Nevermind kbwbe. I found the panel and posted an issue in the GitHub.
Using the A2Plus Workbench:
Menu Edit > Preferences > A2Plus Settings
kbwbe
Post by kbwbe » Sat Jan 18, 2020 3:38 pm
Please update A2plus to version V0.4.40. Issue #336 is fixed and A2plus does not import section surfaces anymore.
KBWBE
papyblaise
Post by papyblaise » Sat Jan 18, 2020 4:01 pm
The Pb is when you use Partdesign , you create substract or add pipe and this create one complex part unsecable
If you need import the duct pipe only you have to do a new separte pipe alone from the Body , event in a new body or more simply in Part Wb , and you use the same path and the same duct cross section
Who is online
Users browsing this forum: bzowk, Chris_G, Forthman and 11 guests
