Export sketch to DXF
Murmele
Post by Murmele » Wed Jan 15, 2020 4:11 pm
I have a sketch created from a step model I would like to export as DXF to import it into KiCad. Trying to import into KiCad I'm getting the error message "No graphic items found in file to import".
I opened the file in LibreCad and saw that the dxf does not consist simple lines which are moveable, but a complex part which I cannot modify, just moving as complete (When I'm creating a simple multiline sketch, in LibreCad I can move the single lines around without moving the others). This might be the reason KiCad is not able to open it because it's to complex.
Do anybody know why FreeCad exports the part as one and not each line separated?
I deleted in a second sketch (Sketch001) the most of the sketch out, because otherwise it is quite slow.
It is the Flatpak version:
OS: Linux 5.4.8-arch1-1
Version: 0.18.14555 (Git shallow)
Branch: (HEAD detached at 0.18.4)
Python version: 2.7.15
Qt version: 5.12.5
MBXL_RA_RCPT_2P24S2P.dxf
Exported dxf
(1.61 KiB) Downloaded 11 times
MBXL_RA_RCPT_2P24S2P.FCStd
(127.15 KiB) Downloaded 16 times
Murmele
Re: Export sketch to DXF
Post by Murmele » Thu Jan 16, 2020 10:09 pm
Is this a bug?
Forthman
Post by Forthman » Thu Jan 16, 2020 10:48 pm
i select the sketch, ctrl+e (export)
and... it works
test.dxf
(38.4 KiB) Downloaded 9 times
Murmele
Post by Murmele » Thu Jan 16, 2020 11:11 pm
Yes I'm able to export, but when opening in LibreCad it's a single part, not multiple lines. I'm not able to import into KiCad
wandererfan
Post by wandererfan » Fri Jan 17, 2020 12:06 am
Is this one any better? It seems to be individual lines in LibreCAD.
mbxl_ra_rcpt.dxf
(54.81 KiB) Downloaded 10 times
Forthman
Post by Forthman » Fri Jan 17, 2020 6:11 am
otherwise you can use the command "explode" in librecad to... explode a block ;)
Murmele
Post by Murmele » Fri Jan 17, 2020 4:33 pm
Hi wanderfan,
yes this is what I wanna have, thank you. This dxf I can open in KiCad too. How did you export it to have individual lines?
Hi Forthman,
yes this works too, thank you!
wandererfan
Post by wandererfan » Fri Jan 17, 2020 6:18 pm
There are 2 Dxf exporters - one in the Draft module ("Legacy python exporter") and one in the Import module. Sometimes one works better than the other.
In this case I used the one from the Import module. Just change the preference, then select the Sketch, then File>Export (AutoDesk Dxf).
Roy_043
Post by Roy_043 » Fri Jan 17, 2020 9:47 pm
The OP is using V0.18 which does not have the 'Use legacy python exporter' option. So the OP would have to switch to V0.19.
wandererfan
Post by wandererfan » Sat Jan 18, 2020 12:43 am
In v0.18, make a TechDraw view of the sketch and use "export page as Dxf" or this in the python console:
>>> import Import
>>> s = App.ActiveDocument.Sketch
>>> Import.writeDXFObject([s], "mbxlv18.dxf")
Who is online
Users browsing this forum: Bing [Bot], galljj, wandererfan and 13 guests
