Hi.
I am learning FreeCAD and I have some problems with point selection. I have seen in some videos that when you want to draw a line between two points, when you hover over a line, FreeCAD automatically highlights the selected points, for example midpoint, and presents them as a solid circle. I imagine that for FreeCAD to do this it is necessary to indicate it in the preferences, but I cannot find it. I have already looked at many tutorials and I have searched this forum, but I cannot find the answer. Can someone help me?
Thanks. Regards.
Highlight points
Re: Highlight points
Hi.
Thanks for your wellcome.
Exactly, I'm talking about Draft workbench. Unfortunately, the page you indicate is not my doubt. I had already visited it and it doesn't indicate anything about what I want to get. What I want to appear is what you see in the following image:
In the video FreeCAD automatically detected the midpoint of the line and placed a white solid circle at that point. I don't get FreeCAD to do this. I think it must be something of the program configuration, but I can't find it. Where is it?
Thanks. Regards.
Thanks. Regards.
- papyblaise
Hi
Just under your nose , in the "Snap tools bar , you have to verify if the adhequat button is greis or blue , if greis clik on it became bleue
Hi.
I know that I have to activate the type of point I want to select (endpoint, midpoint, intersection, ...) in the Snap tools bar, but that isn't then problem. Although the button is activated, I cannot do what I have said in the previous messages.
Thanks. Regards.
Thanks. Regards.
- papyblaise
I don't use that very often , but I can verify now when all the bar is active nothing work maybe to many , unselect the majority and save only one or two , at home it's work like that
Hi.papyblaise wrote: ↑Thu Jan 16, 2020 4:11 pm I don't use that very often , but I can verify now when all the bar is active nothing work maybe to many , unselect the majority and save only one or two , at home it's work like that
The problem is the same with the entire bar activated or with a single activated type.
Thanks. Regards.
Hi.
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Spanish/Spain (es_ES)
Is it enouhg?
Thanks. Regards.
