Part compound: Color not handled properly
Roy_043
Post by Roy_043 »
If I have two Part primitives with distinct shape colors and and use them as base objects for a Part Compound, the nested objects retain their color even though the compound has its own (different) shape color. But if I then change the shape color of the compound the color of the nested object is overridden. This is strange obviously. But stranger still: If I next change the position of one of the nested objects, the shape color of the nested objects again has priority over that of the compound. Seems like a bug to me.
OS: Windows 8.1 (6.3)
Version: 0.19.19263 (Git)
Hash: c4ca00a1d5b7922ef1d2ae3e820bb34ffdb64d9f
Python version: 3.7.3
Qt version: 5.12.5
thomas-neemann
Re: Part compound: Color not handled properly
Post by thomas-neemann »
Roy_043 wrote: Fri Jan 17, 2020 3:14 pm
I currently have the problem that if I want to move an "assembly" with differently colored parts with transform, I create a compound. most of the time the colors stay the same, which is what i intend to do. they sometimes get lost with complex assemblies, i haven't been able to reproduce it so far. While searching for the problem I came across this post.
I can confirm
edit
same with draft upgrade
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.21.0.33345 (Git) AppImage
Hash: a3c4f4bb01f5201daf666852444a8f9c5adbda8d
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Last edited by thomas-neemann on Fri Jun 02, 2023 8:06 am, edited 1 time in total.
thomas-neemann
keeps the colors, but after taransform i can't dissolve it again without losing the colors.
everything works with box selection, draft move/rotate
thomas-neemann
this works in all cases (so far)
viewtopic.php?t=78765
