/science/OpenSUSE_Leap_15.1/
/science:/unstable/OpenSUSE_Leap_15.1/
(see https://build.opensuse.org/package/show ... eeCAD-test)
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/default)
Version: 0.19.Unknown
Python version: 3.6.5
Qt version: 5.9.7
OCC version: 7.4.0
When opening FreeCAD and changing from WB "Start" to "PartDesign" I get this:
Report view:
Wizard shaft module cannot be loaded
/usr/lib64/FreeCAD/lib64/Sketcher.so: undefined symbol: _ZNK22Geom_ElementarySurface4AxisEv
File "<string>", line 50, in Initialize
Python console:
Python 3.6.10 (default, Jan 16 2020, 09:12:04) [GCC] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.runCommand('Std_ViewStatusBar',1)
>>> Gui.runCommand('Std_ViewStatusBar',0)
>>> Gui.runCommand('Std_Workbench',22)
>>> ### Begin command Std_Workbench
>>> Gui.activateWorkbench("PartDesignWorkbench")
>>> ### End command Std_Workbench
Report view:
File "<string>", line 43, in Initialize
Python console:
>>> Gui.activateWorkbench("PartWorkbench")
Report view:
/usr/lib64/FreeCAD/lib64/Part.so: undefined symbol: _ZNK22Geom_ElementarySurface8PositionEvError: Initializing one or more of the Draft modules failed, Draft will not work as expected.
Unknown command 'Draft_Line'
Unknown command 'Draft_Wire'
Unknown command 'Draft_ArcTools'
Unknown command 'Draft_Circle'
Unknown command 'Draft_Ellipse'
Unknown command 'Draft_Rectangle'
Unknown command 'Draft_Polygon'
Unknown command 'Draft_BSpline'
Unknown command 'Draft_BezierTools'
Unknown command 'Draft_Point'
Unknown command 'Draft_Facebinder'
Unknown command 'Draft_Text'
Unknown command 'Draft_ShapeString'
Unknown command 'Draft_Dimension'
Unknown command 'Draft_Label'
Unknown command 'Draft_Move'
Unknown command 'Draft_Rotate'
Unknown command 'Draft_Offset'
Unknown command 'Draft_Trimex'
Unknown command 'Draft_Join'
Unknown command 'Draft_Split'
Unknown command 'Draft_Upgrade'
Unknown command 'Draft_Downgrade'
Unknown command 'Draft_Scale'
Unknown command 'Draft_Edit'
Unknown command 'Draft_SubelementHighlight'
Unknown command 'Draft_WireToBSpline'
Unknown command 'Draft_Draft2Sketch'
Unknown command 'Draft_Shape2DView'
Unknown command 'Draft_ArrayTools'
Unknown command 'Draft_Clone'
Unknown command 'Draft_Drawing'
Unknown command 'Draft_Mirror'
Unknown command 'Draft_Stretch'
Unknown command 'Draft_Layer'
Unknown command 'Draft_Heal'
Unknown command 'Draft_FlipDimension'
Unknown command 'Draft_ToggleConstructionMode'
Unknown command 'Draft_ToggleContinueMode'
Unknown command 'Draft_Slope'
Unknown command 'Draft_SetWorkingPlaneProxy'
Unknown command 'Draft_AddConstruction'
Unknown command 'Draft_ApplyStyle'
Unknown command 'Draft_ToggleDisplayMode'
Unknown command 'Draft_AddToGroup'
Unknown command 'Draft_SelectGroup'
Unknown command 'Draft_SelectPlane'
Unknown command 'Draft_ShowSnapBar'
Unknown command 'Draft_ToggleGrid'
Unknown command 'Draft_AutoGroup'
Python console:
>>> Gui.activateWorkbench("DraftWorkbench")
