[Solved] 0.19pre PartWB, Attachment >Apply, donnot work
- DeepSOIC
Re: 0.19pre PartWB, Attachment >Apply, donnot work
As for apply button - yes, it's my screwup, restarting transaction from there makes sense. Removing the apply button altogether is also an option.
Thank you. I tried above fix, but cannont find difference between "OK" and fixed "Apply".
As my understanding, "Apply" change source object position, but leave "map mode/attachment mode" untouched (or reset). Or say, "Apply" could work as non-parametric alignment.
Please correct me, if I am wrong here.
- DeepSOIC
Apply was made to record the state of attachment to the object. Then you can change something, and click Cancel, and the changes will be reverted to those written when you clicked "Apply".
This is something that deserves a special button maybe. "Apply" doesn't imply that, in my opinion.
Thank you, got it.
"Cancel" button misfunction in "Native" Attachment editor still need another fix, what's your opinion?
Yep, that's what it induces. Because no Undo transaction is opened, neither Cancel, nor Undo after OK works correctly. I'm preparing a PR as @wmayer jumped over this.
Are you sure about that?
In any case, Werner did what I suggested, commit and open again, git commit c32c9d565.
I'm sure. The problem I'm talking about lies in https://github.com/FreeCAD/FreeCAD/blob ... tacher.cpp
git commit bd0f5ca5c
Obviously there is a regression compared to v0.18 because there it opened a transaction. It looks like the auto-transaction mechanism is not technically mature.
In order to get the undo/redo working as expected I had to remove the check whether the AttachmentOffset is touched and the property MapPathParameter must be explicitly set too.
Now it works to reject the dialog or when accepting it then undo & redo works. However, I still encounter a weird problem: undo & redo works exactly 5 times and after doing undo the 6th time the placement of the object is not set correctly any more.
I have reported this in https://tracker.freecadweb.org/view.php?id=4265#c14271
