Display of a point not attached to the lines outside the sketch.
Dude
Post by Dude » Sun Mar 29, 2020 4:41 pm
In general, how to make sure that points that are not at the intersection of two visible lines are displayed outside the sketcher. I need to see these points to place the auxiliary planes. I tried to make points at the intersection with additional visible lines, but you cannot extrude a sketch with extra visible lines.
Снимок экрана_2020-03-29_21-06-15.jpg (197.82 KiB) Viewed 255 times
Снимок экрана_2020-03-29_21-06-36.jpg (59.76 KiB) Viewed 255 times
And another question, the mouse wheel, in addition to turning the page, additionally flips through a menu like this.
Снимок экрана_2020-03-29_21-36-52.png (1.9 KiB) Viewed 255 times
And when I leaf through the page, the cursor comes across a menu and starts changing it. It is very inconvenient how you can turn off the parameter change with the mouse wheel.
TheMarkster
Re: Display of a point not attached to the lines outside the sketch.
Post by TheMarkster » Sun Mar 29, 2020 5:29 pm
Here is a way, but it is a hack and would only work in 0.19, and possibly only a very recent build.
phpBB [video]
An alternative would be to create a second sketch only to be used as the reference, consisting of a visible line segment connected from one point to the other. The circle would be construction mode in that other sketch.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
Dude
Post by Dude » Sun Mar 29, 2020 7:07 pm
Thanks for the work. I just want to know that this is really impossible to do with default tools. I will wait for more feedback, and try to give a request for such a function. Auxiliary geometry is already implemented, and this feature will give much more functionality.
TheMarkster
Post by TheMarkster » Sun Mar 29, 2020 7:13 pm
I see. Points are currently always treated as construction mode geometry. An option to have them either normal mode or construction mode might make sense, but I'm sure this has already been discussed (and probably proposed) many times.
vocx
Re:
Post by vocx » Sun Mar 29, 2020 7:45 pm
...Auxiliary geometry is already implemented, and this feature will give much more functionality.
Why don't you add a datum point (PartDesign_Point) or coordinate system? That's the reason datum objects were created, to serve as auxiliary geometry that is common to the entire PartDesign Body, not only to a single sketch.
Dude
Post by Dude » Sun Mar 29, 2020 8:31 pm
I can’t snap the auxiliary point in the part design to the sketch points, if the sketch point is not visible at part design. If this is possible in an adequate way, tell me please.
Post by chrisb » Mon Mar 30, 2020 12:36 am
There is already a feature request for this.
mario52
Post by mario52 » Mon Mar 30, 2020 4:47 pm
hi
and if ... use the point line
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
Dude
Post by Dude » Mon Mar 30, 2020 8:33 pm
The line is not tied to the sketch, the parameterization is lost. If there is a request for a function, then I will wait.
And the essence is not only in a straight line with a point, but in any sketch geometry that can be use in outside.
freedman
Post by freedman » Tue Mar 31, 2020 3:32 am
You can make a master sketch with a line, attach a datum line, then a datum plane.
out_plane.FCStd
(6.36 KiB) Downloaded 1 time
Who is online
Users browsing this forum: chrisb, kisolre, martin51, Rasputin and 16 guests
