Help with PartDesign Body
getSurreal
Post by getSurreal » Mon Mar 30, 2020 5:54 pm
I'm struggling with the best way to extrude when the parts aren't a single solid. I found it much easier to do this type of design in v0.16 where I could put all the constraints into a single sketch. I find it difficult to get the precision when using mirror or array, but maybe there's an easier method.
Attached is a very basic example, but imagine the posts being more complex objects.
PadPosts.FCStd
(8.92 KiB) Downloaded 3 times
Re: Help with PartDesign Body
Post by chrisb » Mon Mar 30, 2020 6:03 pm
What I see in your model could b done very well in current FreeCAD's PartDesign, because starting with the plate and adding the posts would always be a single solid.
However if you have to start with the 3 posts, you would have to use Part->Extrude.
getSurreal
Post by getSurreal » Mon Mar 30, 2020 6:11 pm
OK, I guess I misunderstood that the sketch could contain separate parts as long as they were attached to a common solid.
drmacro
Post by drmacro » Mon Mar 30, 2020 6:19 pm
Just expand on what chrisb said.
Part > Extrude can create non-contiguous solids, with out substrate.
Part Design > Pad cannot.
With your sketch, I extruded in Part WB, then created a Part Design Body
PadPosts-mac.FCStd
(9.88 KiB) Downloaded 1 time
kisolre
Post by kisolre » Mon Mar 30, 2020 6:34 pm
Still the same issue - every feature under the body after that should result in single solid.
getSurreal
Post by getSurreal » Mon Mar 30, 2020 6:39 pm
Is that planned to be deprecated for Part Extrude in the future?
kisolre
Post by kisolre » Mon Mar 30, 2020 6:44 pm
Which one? For now PartDesign Body should be a single solid. Plans to support multiple solids under one body exist but are not implemented still. Part Extrude can create multiple solids under one part as long as there are no intersecting contours and no nested contours.
drmacro
Post by drmacro » Mon Mar 30, 2020 6:47 pm
Yes.
If the plan is to continue with multiple bodies, then remaining in the Part WB realm is best.
openBrain
Post by openBrain » Mon Mar 30, 2020 7:25 pm
I don't think so. Part & PartDesign WBs aren't competitors. They are different toolboxes for 2 different modeling ways. Both should stay available in the future. ;)
Who is online
Users browsing this forum: easyw-fc, Google [Bot], joea, kisolre, martin51 and 17 guests
