Ticket #4300 - Part object moves to 0,0 when dragged into Part Design Body
drmacro
Post by drmacro » Mon Mar 30, 2020 6:01 pm
With an object formed with a sketches and extrudes and a boolean in Part WB.
I then change the placement of resultant object.
I then create a Body in Part Design WB and drag the previous object into the Body.
The BaseFeature moves to the origin.
Is this desired behavior?
OS: Ubuntu 19.10 (XFCE/ubuntustudio)
Version: 0.19.
Python version: 3.7.5
Qt version: 5.12.4
ParttoPartDesign.FCStd
(21.84 KiB) Downloaded 4 times
Reason: Added ticket number to thread title
Re: Part object moves to 0,0 when dragged into Part Design Body
Post by chrisb » Mon Mar 30, 2020 7:47 pm
Yes. It may be worth a feature request though to
- add AttachmentOffset to BaseFeatures
- add TraceSupport as it is used for ShapeBinders.
openBrain
Post by openBrain » Mon Mar 30, 2020 8:25 pm
Just compound the (lone) Cut (in your example) and use the newly created Compound as BaseFeature. ;)
drmacro
Post by drmacro » Tue Mar 31, 2020 12:47 pm
Intuitively obvious... :roll:
NOT :!:
openBrain
Post by openBrain » Tue Mar 31, 2020 5:29 pm
Actually this is (maybe not obvious), but normal when you know a bit the why.
What happens :
  1. FC computes the shape of the cut
  2. Then it applies the move shift corresponding to the placement
But actually, the internal shape object is still 'referenced' to the computation origin. Thus when you use it as BaseFeature, FC copies the shape only (without placement attributes of the cut) hence it's back to origin.
When you compound the cut, FC recomputes a new shape which actually is the shifted shape of the cut. This means that the cut placement shift has been 'integrated' into the compound internal shape. Hence it is included when using the compound as BaseFeature.
Notice that if you further move the compound with its placement, this won't be included in the BaseFeature (same case as with the cut).
This is a tip I often use to center ShapeStrings, then eventually further move them based on the centered shape. ;)
drmacro
Post by drmacro » Tue Mar 31, 2020 6:31 pm
What happens :
After explanation, the behavior makes sense. But to the end user, who sees on the screen an object that is not at the origin, there's no good reason to expect including in another wrapper (the Body) would move it to origin. Unless, said user is aware that that is the defined behavior. (it may be defined in user docs somewhere, I'm just saying I haven't noted it. ;) and, it may well be defined as SOP in the programming docs. )
In any case, as chrisb suggested, I put in a feature request. If that were to be implemented, then there would be a distinct need to document the outward behavior (what the user sees) and what effect the new feature provides.
And, that indeed is a good tip. :idea: :D
drmacro
Post by drmacro » Fri Apr 03, 2020 2:51 pm
Playing around with this.
- I created a ShapeString at an arbitrary location
- Extruded in Part WB (The extrude remains at the arbitrary location, but Placement value is 0,0,0)
- create body, drag Extrude to body
BaseFeature is at the arbitrary location. I expected, per this discussion, it'd move to global origin. Obviously I missed the point... :?
I thought maybe:
- create Shapestring at global origin
- extrude
- move placement
- drag to body
No error in report view, but it does not create a BaseFeature.
I tried other combinations. Geometry created in a sketch and moved, goes to global origin when dragged into a body.
But, geometry created with a shapestring does not move to origin.
What don't I know or understand? 8-)
Who is online
Users browsing this forum: Bing [Bot], openBrain, PedjaS and 13 guests
