When I tried it Left Bar 1 wouldn't fillet. Others seem ok.
No indication of strangeness in Dependency and no errors in Check Geometry.
Wouldn't have guessed to check that.kisolre wrote: ↑Fri Apr 03, 2020 5:35 pm The issue is that that specific body has its Display mode as Tip. This displays the geometry of the body, which is duplicate of the geometry of its Tip. But is not the Tip feature. So selecting an edge selects Body001.Edge003 and not Body001.Pad005.Edge003. Thys the fillet does not which is its parent feature and does not succeed. Activate Selection View (View/Panels/Selection view) to check what gets selected.
Um...trying to understand the implications.kisolre wrote: ↑Fri Apr 03, 2020 5:49 pm "Tip" is the feature from which the Body derives its Shape. When you select the body and export it what is exported is the Tips shape. Also "Tip" is the parent for the added features. By changing the tip you can add features in the middle of the Body tree. Just don't forget to later change it back to the last feature.
Thanks, had to read the links a couple times and toggle things a LOT, but I think I see.kisolre wrote: ↑Fri Apr 03, 2020 7:21 pm PartDesign_MoveTip
The Tip is marked with small down arrow in green circle. Display mode is a View property of the body that sets what geometry is displayed.
https://wiki.freecadweb.org/PartDesign_Body#Tip
and
https://wiki.freecadweb.org/PartDesign_Body#View
I have come across that before. It is an issue between using FreeCAD on Mac vs PC.drmacro wrote: ↑Fri Apr 03, 2020 7:50 pmThanks, had to read the links a couple times and toggle things a LOT, but I think I see.kisolre wrote: ↑Fri Apr 03, 2020 7:21 pm PartDesign_MoveTip
and
