Intersection of 2 protrusions [SOLVED]
Hello,
I'm using FreeCAD 0.18 on Linux.
I made a sketch in the plan XY and protrusion in the direction Z
I made a sketch in the plan XZ and protrusion in the direction Y (see the screen capture)
The 2 sketches are working fine (no error).
The 2 protrusions are fine too.
When I make a boolean intersection of these two parts,
there is no error,
but the result called "common" is empty.
Please is it a known bug or I am I doing something wrong ?
there is no error,
- FreeCADcommon.png (146.38 KiB) Viewed 1885 times
- microelly2
Re: Intersection of 2 protrusions that should not be empty
Welcome to the forum.
Can you upload the file?
Sometimes there are errors if the parts have faces in the same plane.
Maybe this is the reason.
Hi, Welcome
As @microelly2 said, I think there are coplanar faces between the 2 solids. This is known to lead to errors in boolean operations.
Thank you very much for your help.
I didn't find any coplanar faces.
I uploaded the file.
- FrontBase0.FCStd
- Protrusion intersection error
- (20.72 KiB) Downloaded 67 times
Just forcing a full recompute makes it OK here (right-click model name 'FrontBase0' in the TreeView, click 'Mark to recompute', press 'F5').
In case of the boolean "cut" would work better than the "intersection", i reversed the sketch and cut.
It's better but one zone that shoud have been cut is still here.
Recompute doesn't work here (neither with intersection or cut).
It looks like a Bug.
- FreeCADcommon2cut.png (156.7 KiB) Viewed 1844 times
- FrontBase1cut.FCStd
- (74.35 KiB) Downloaded 68 times
It's visible why on your screenshot. A cut line is perfectly aligned with a seam line. This sometimes can lead to problems similarly to coplanar faces.
Coplaner issue.
I moved SketchXZ .1mm and all is good:
- FrontBase1cut_mac.FCStd
- (58.76 KiB) Downloaded 62 times
OK, I new for coplanar faces, but I never had any problem with lines.
Thank you very much it works now.
Well, basically any sketch that creates or geometry that ends up coplaner can cause the issue.
