[4. WB-Sketcher-works] // tested in FreeCAD 0.19_pre
TASK: guideline -> profile
1. Attaching sketch to entity
Have a sketch, select an edge, press
[map a sketch to face] -> get a selection menu pop-up -> select sketch by name -> select attachment mode:
-- normal to edge
-- InertiaCS ( normal to the middle of edge)
Done: the sketch will be attached to the position of the edge
The edge can be any line: from sketcher, or Draft or an edge from body.
Work-Flow optimisation: no need to make repetitive sketching: make a copy of existing sketch and attach it to selected guideline.
Usage: use with Sweep(Part, PartDesign), Pad(PartDesign) -> get a profile, sweeped along the selected edge
See also: bidirectional Pad
2. Bidirectional Pad
If there is a sloped end of profile:
WBPartDesign:
-- attach a sketch to edge at intertiaCS (see description 1. in this post)
-- Pad Sketch "to face" one side
-- Select sketch from inside the first pad and Pad that Sketch "to Face" - to opposite side
-- If needed -> goto Object Properties refine:=true - this will remove the line of boundary between two pads.
## GOTO header post:
https://forum.freecadweb.org/viewtopic. ... 09#p421709
