(Note Constraint7/tmax is a reference dimension because the vertices it is measuring are in the external (shapebinder). If I attempt to use tmax in an expression in Constraint6 : But, Constraint6 needs to be some percentage of tmax (that percentage will ultimately come from a spreadsheet).
So an expression like this is the goal:
tmax * Spreadsheet.somepercent
(that scale will ultimately come form the spreadsheet as well.)
So, the question is how to access the distance between those particular vertices.
