STEP export retains only some colors
i want to color in some faces of a 3D object in Freecad. But i have some trouble with that, not all parts
keep their color after the export. I have here a simple example of a PCB, you can see the color of the PCB
is in the export but the pads on the back are not. Do i have to convert it somehow or what is going on?
before: https://pasteboard.co/JqugoeA.png
after: https://pasteboard.co/Jqugvg5.png
Here is the file for you to try out https://www.dropbox.com/s/j738rb1ebtrjj ... .step?dl=0
- 2.PNG (43.5 KiB) Viewed 875 times
- 1.PNG (37.86 KiB) Viewed 875 times
Re: STEP export retains only some colors
No one has an idea why?
If I import your Step file FreeCAD 0.19 hangs. And anyway to really help you we would need a FreeCAD file.
I also cannot open the Step files I create myself from the forum.FCStd file. I do not know why. Maybe somebody else can assist?
I have no issue when exporting/importing the file to step
here my FC info
here my FC info
and my Import/Export settings It works fine also when deselecting legacy exporter.OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: f5710fb5cf551b026617f6248afd5cc2c48a3750
Python version: 3.8.2
Qt version: 5.12.8
Thanks, that is useful information. The issue with FreeCAD hanging seems not related to the STEP import/export settings. Further testing shows that the problem is related to the FreeCAD (Coin?) version.
OK version:
OS: Windows 8.1 (6.3)
Version: 0.19.21764 (Git)
Hash: ccea55a65512d37081d708d6f504d0c4d182a9e0
Qt version: 5.12.5
OCC version: 7.4.0
Version: 0.19.22366 (Git)
Hash: 34c11fcc63efa2fc72cbc74c75c76e9f19d5c84c
Python version: 3.6.8
Qt version: 5.12.1
@gjl31919:
With the version listed below, and the settings from @easyw-fc I am able to create a Step file with correct colors.
BTW: As you can see, you can attach files directly to a forum post.
Qt version: 5.12.5
OCC version: 7.4.0
- Forum_Roy.zip
- (207.23 KiB) Downloaded 15 times
Amazing thanks i will try that, yes a just saw the Attachement feature
Is there a way to get that working in version 18 the tools im using are not ported to the V19, to import from my PCB CAD software to Freecad. Also i have noticed if i export this as a step file and import it to any other CAD software (i.e. CATIA etc) i only get the PCB but not the components. They appear in the part tree but are not shown/empty. Thanks already for the Trouble shouting.
- TEC305 3D.FCStd
- (1009.35 KiB) Downloaded 11 times
