[BUG #4467] Malformed Constraints
TedM
Post by TedM » Sun Oct 18, 2020 4:55 am
Edit 3: I have successfully reproduced this bug. The procedure is shown in this reply: https://forum.freecadweb.org/viewtopic. ... 98#p440598
Edit 2: It appears I was wrong when I wrote to disregard this in the first edit below.
Edit: I was seeing some other "funny" stuff happening so I closed FreeCAD and restarted it. The issue shown below has disappeared! It appears to have been some internal corruption, source unknown. This report is of little value but I decided to leave it up, just in case.
OS: Windows 10 (10.0)
Version: 0.19.22665 (Git)
Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99
Python version: 3.8.6
Qt version: 5.12.9
OCC version: 7.4.0
I have a sketch I've created and I'm getting the following in the report view panel:
21:46:03  Sketcher constraint number 6 is malformed!
21:46:03  Sketcher constraint number 33 is malformed!
21:46:03  Sketcher constraint number 51 is malformed!
21:46:03  Sketcher constraint number 68 is malformed!
21:46:03  Sketch Sketch033 has malformed constraints!
There doesn't seem to be anything obviously wrong with the sketch and Validate Sketch shows no errors. Also, if I go, delete constraint #6 and recreate it, it then reports that constraint #5 is now malformed. (I'd previously recreated constraint #7 which was "malformed", resulting in #6 becoming "malformed".)
In any case, despite these reports, the sketch seems to function correctly.
I had previously created the sketch and then did other things with the document. I have no idea when this started happening. I just recently noticed the red message "Sketch Sketch033 has malformed constraints!" flashing on the bottom of the screen. I do not have the report view opening automatically.
Anyone have any idea what's happening? Anyone seen this before?
Thanks
malformed constraints.FCStd
(6.77 KiB) Downloaded 15 times
Re: [DISREGARD] Malformed Constraints - Help?
Post by chrisb » Sun Oct 18, 2020 6:58 am
I'm sad to say, but the error returns immediately if you recompute the sketch. The numbers you see in report view have an offset of 1, Constraint number 6 from the message is Constraint7 in the GUI.
Not time to look in detail now, but did you use Expressions in your Sketch?
TedM
Post by TedM » Sun Oct 18, 2020 8:30 am
Yes. My design is parameterized using a spreadsheet. I stripped out all of the expressions and the spreadsheet to make the sample document for the post.
Post by chrisb » Sun Oct 18, 2020 8:49 am
The message says among others that "constraint number 68 is malformed". According to my remark above you have to look at Constraint69 in the sketch.
It is a constraint between the center of the lower construction circle and the origin. Obviously they are not coincident. If I remove that constraint the sketch is still fully constrained, but one error message is gone!
The same with Constraint52, Constraint34, Constraint7. Remove them all and the messages have gone and the sketch is still fully constrained.
It would be very interesting to know what you have done to enter that state.
bambuko
Post by bambuko » Sun Oct 18, 2020 9:34 am
Edit: I was seeing some other "funny" stuff happening so I closed FreeCAD and restarted it. The issue shown below has disappeared!...
No, it hasn't dissapeared ;) as confirmed by chrisb and myself.
... It appears to have been some internal corruption, source unknown...
No, it is not some corruption - it is simply "unfinished" sketch :ugeek:
...This report is of little value but I decided to leave it up, just in case...
Not at all, it has provided me with a good lesson.
BTW I also had problems with symmetry constraint when first started using FreeCAD :mrgreen:
...Anyone have any idea what's happening? ...
Yes, it is the way you have used little segments of construction lines (notice, that all "offending" constraints are at the nodes when two or more of your construction lines meet)
...Not time to look in detail now, but did you use Expressions in your Sketch?
No, it is nothing to do with expressions (as mentioned above - get rid of all these construction lines and the problem dissapears).
I enjoyed having a go at constraing the sketch differently (see attached)
Hopefully, it helps ;)
I would edit thread title and remove DISREGARD - your question was pefectly valid
malformed constraints-test.FCStd
(7.44 KiB) Downloaded 6 times
Post by chrisb » Sun Oct 18, 2020 12:53 pm
Not true I think, there is something corrupted. There are constraints which should show the sketch as unsolvable or at least as overconstrained.
That's a cheap trick: It would remove the offending constraints by simply removing the geometric elements they are attached to, but it doesn't explain how this could have happened.
If you are sure that it is indeed just unfinished, then it would help if you could create such behaviour from scratch and tell us how it can happen.
bambuko
Post by bambuko » Sun Oct 18, 2020 1:07 pm
...If you are sure that it is indeed just unfinished, then it would help if you could create such behaviour from scratch and tell us how it can happen.
OK, challenge accepted ;)
Will be back...
bambuko
Post by bambuko » Sun Oct 18, 2020 4:11 pm
Well, it was good learning exercise, trying to re-create what someone else has managed,
but it has also proved that I was talking out of my rear orifice :mrgreen:
I was unable to recreate the error.
Rather annoying, everyting I have tried ended with perfectly constrained sketch with no error messages.
I have no clue how constraints 7, 34, 52 and 69 happened to be created :oops:
Sounds like I have reached level of my incompetence :lol:
Sorry
TedM
Re: Malformed Constraints - Help?
Post by TedM » Sun Oct 18, 2020 7:07 pm
OK, I went back and was able to reproduce this problem very easily! It seems to be a problem with Clone in Sketcher.
To reiterate the FreeCAD version:
Qt version: 5.12.9
OCC version: 7.4.0
Here is the procedure to reproduce it:
1. Start FreeCAD.
2. Open the report view panel at the bottom of the screen.
3. Create a new document.
4. Go to the Part Design WB.
5. Create a body.
6. Create a sketch on the XY plane.
7. Place a circle, not constrained in location and contrain the radius to 2.5mm.
8. Place a line with one end constrained to the center of the circle and the other end to the right. Add a horizontal constraint and a length constraint of 14mm.
9. Select both objects and then slowly double-click the center of the circle so that everything is still selected and the circle center is last selected.
10. Clone the objects and move the clone reference point onto the right end of the line so that the
constrain coincident.jpg (1.06 KiB) Viewed 108 times
symbol shows to make the cloned circle constrained to the old line and release the mouse button.
11. These errors will immediately appear in the report window:
12:03:06  Sketcher constraint number 8 is malformed!
12:03:06  Sketch Sketch has malformed constraints!
Here is the result of this procedure:
malformed constraints created.FCStd
(5.19 KiB) Downloaded 2 times
GeneFC
Re: [BUG} Malformed Constraints
Post by GeneFC » Sun Oct 18, 2020 7:28 pm
I can confirm that when following the instructions exactly I see the malformed constraints.
On the other hand if I just select the line and the circle rim (not the circle center) it works exactly as desired. The center of the circle triggers the coincident icon when it overlays the end of the line.
Not sure how it should work. My guess is that some sort of redundant constraint is created, since the center of the circle is already selected as the operation point. Repeat selection of the center is likely the cause of the problem.
Of course any such error is a bug unless it is clearly forbidden.
Gene
Who is online
Users browsing this forum: Google [Bot], m0n5t3r and 23 guests
