small grid thing won't disappear
Hello, i cant seem to figure out how to remove this small grid thing from the screen. Ive unchecked the show grid option and this other bigger grid disappeared but this small one is still there. Ive attached photo of it. Thanks.
- cad.png (444.39 KiB) Viewed 905 times
Re: small grid thing won't disappear
Hi possibly it might be from Draft Workbench. Can try going to Draft Workbench and in Utilities / Toggle Grid. Don't use Draft and grid in my shows rulers (posssibly a setting) but goes away when I toggle grid.
im having the exact same issue now aswell, tried what was said here but doesnt work. Tbh this program is a real "edit by moderator" of a thing.
Reason: removed foul language
pretty sure it's the draft workbench grid. typically gets toggled on when draft workbench is selected.
exit the Sketcher and use keyboard shortcuts g r to toggle it off.
Thank you drmacro for
"Last edited by jmaustpc on Sat Oct 24, 2020 7:00 am, edited 1 time in total.
Reason: removed foul language"
I think that it is unlikely that this is the Draft grid. For one thing it does not have the default appearance and colors of a Draft grid. The OP should post a file.
Seems like neither poster wishes to follow procedure and post their FreeCad information, don't know for sure but the screenshot could be a function of OP's monitor or screen capture resolution.
Have backed up and reset preferences. Am able to produce a very similar screenshot albeit on a high resolution monitor.
Tend to agree without having further information with
Switching back to my backed up configuration.
- Sample.FCStd
- (6.05 KiB) Downloaded 17 times
Sorry, I get no grid..
OS: Ubuntu 20.04.1 LTS (XFCE/ubuntustudio)
Version: 0.19.
Branch: unknown
Hash: cda1205c3ee8097905d7df77167dce6c8c352e4a
Python version: 3.8.5
Qt version: 5.12.8
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
You right. I opened and no grid. Had to go to draft preferences and set to use grid. Then had to save and exit and open file. Don't fully understand, thought the settings would be in the saved file. Sorry. Also may have to open Draft Workbench. Can't repeat what sequence triggers the grid. Did find needed use grid setting and restart. Note not blue, switched back to my preference of white.
