Create cross section from a Part
qwerty_f
Post by qwerty_f » Mon Oct 19, 2020 10:32 am
I wonder what would be a good way to create a cross-section of a Part. So far I only have seen cross-sections on bodies. But here I have a Part where various bodies are assembled and I want to create another Part which references these assembled bodies.
qwerty_f
Re: Create cross section from a Part
Post by qwerty_f » Mon Oct 19, 2020 11:05 am
P.S. I just found the new Link feature which might be a way to solve my issue. I'm open for suggestions, though.
drmacro
Post by drmacro » Mon Oct 19, 2020 12:19 pm
Use Part WB "make compound" of the Part objects (I'm assuming you have yellow part containers), then use Part WB "Cross-sections"
My beginners, written treatise: Learning FreeCAD
qwerty_f
Post by qwerty_f » Mon Oct 19, 2020 12:25 pm
Yes, I'm using the yellow Part. But where do I find that?
(as a side question: where can I find my old posts since I want to edit one)
drmacro
Post by drmacro » Mon Oct 19, 2020 12:57 pm
As I said: "Use Part WB "make compound" of the Part objects (I'm assuming you have yellow part containers), then use Part WB "Cross-sections"
Part WB (workbench) "make compound" Image
Part WB (workbench) "Cross-sections" Image
qwerty_f
Post by qwerty_f » Mon Oct 19, 2020 1:13 pm
Found it. It was grayed out since I had a task open :-/ Will see if that help. Thanks!
qwerty_f
Post by qwerty_f » Mon Oct 19, 2020 3:21 pm
Ok, so I found that and made a cross section. But then, how can I use the created cross section for further reference? The documentation about that topic is a bit thin.
drmacro
Post by drmacro » Mon Oct 19, 2020 5:25 pm
At that point it is not really connected to the source object. So, it is not parametric (i.e. if the original object changes it won't follow).
You can convert to a sketch. You can upgrade it to a face. You can extrude it. Some other things as well...
qwerty_f
Post by qwerty_f » Tue Oct 20, 2020 12:50 pm
Thanks for your patience, I'll try that.
qwerty_f
Post by qwerty_f » Tue Oct 20, 2020 1:45 pm
I did not have much luck with that compound. It just behaves weird. Anyhow, I'm just watching this YT video which seems to address my issue in a "intended" way.
Who is online
Users browsing this forum: m0n5t3r and 21 guests
