Template issue in Techdraw (FC 0.19)
gigax
Post by gigax » Tue Oct 20, 2020 2:59 pm
Hello All,
I am a new forum user and I have been using FC for about 6 months in a professional environment. The engineering company where I work focuses on electronic products, and we are currently using FC 0.19 to design sheet metal enclosures (Part, FEM, SheetMetal, TechDraw).
We are facing an issue with TechDraw and we did't find a solution yet.
Usually we create multiple TechDraw sheets in a project, based on the same template which is saved in a certain path (for example c:\templates\mytemplate.svg), and everything works well while the document is open.
If we close and reopen the same document, we have these problems:
1) The "TEMPLATE" paths for all TechDraw sheets are modified to a temporary folder, and the template file names have an added progressive number to it (mytemplate1.svg, mytemplate2.svg...etc...). The same paths and file names appear in the PAGE RESULT fields.
2) The system gives error messages: "Failed to recompute...." as it cannot open those templates named mytemplate1.svg and so on, so we always need to select the right template and fill all the fields manually.
Are we doing some mistakes, or is there some setting to be adjusted?
thanks in advance for your help!!!
OS: Windows 10 (10.0)
Version: 0.19.21049 (Git)
Hash: 9c27f1078e5ec516fe882aac1a27f5c6c6174554
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Italian/Italy (it_IT)
Re: Template issue in Techdraw (FC 0.19)
Post by chrisb » Tue Oct 20, 2020 4:26 pm
Hi and welcome to the forum!
Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above. It should not be necessary to reload the template every time. AFAIK it is used only when creating the page.
gigax
Post by gigax » Tue Oct 20, 2020 7:18 pm
Thank you chrisb, I have edited my post and added the FreeCAD info.
mendy
Post by mendy » Tue Oct 20, 2020 8:21 pm
Hello
Have been playing with a file.
The file below shows this to be normal? If I open it with my archive manager it does show the three svg files in numerical sequence.
Initially while file is open it is different but upon closing and reopening it shows as tmps.
Doesn't give this message for me and file opens.
Thought maybe settings in preferences but didn't change my set custom ones and opened a A4 Techdraw Template.
Possibly misunderstanding your workflow.
Are you entering data on each sheet as you go. Did find if I change template on page it does delete data entered.
Or are you trying to duplicate the data to multiple sheets?
Would you have an example file with no proprietary information using standard templates to upload?
In my file just changed the Title to save time.
Edit: Spelling Twice
Block Sample.FCStd
(46.8 KiB) Downloaded 3 times
gigax
Post by gigax » Wed Oct 21, 2020 3:11 pm
Many thanks for your reply Mendy.
Actually I think that I have understood the cause of this problem and fixed it by myself, so let me share this as it may be useful for others.
The problem was caused by CCleaner, which is set to run automatic system cleans on a daily basis on my PC. So, it just deleted the temp files created by TechDraw.
I have added an exclusion rule in CCleaner, in order to prevent it from deleting *.SVG files, and since then the issue didn't happen anymore.
Keeping my fingers crossed...
Thanks!
Who is online
Users browsing this forum: m0n5t3r and 26 guests
