How to create a non planar path to be used for a sweep
Greyble
Post by Greyble » Tue Oct 20, 2020 8:25 pm
I'd like to be able to sweep or loft a profile over a path that is non planar. I've attached a mock up hopefully it'll help explain the issue.
In the PartDesign WB I created a bowl as a body. Using this I wish to create a 'cradle' that spirals out from the base (in XY plane) and at the same time rises to touch the outside of the bowl - i.e the actual path looks like part of a spiral when projected onto the XY plane and part of an elipse when projected onto say the XZ plane.
Bowl.FCStd
(86.77 KiB) Downloaded 12 times
TheMarkster
Re: How to create a non planar path to be used for a sweep
Post by TheMarkster » Tue Oct 20, 2020 10:47 pm
Perhaps a helix would be better than a spiral?
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
Post by chrisb » Tue Oct 20, 2020 10:49 pm
Have a look at the addon macro "3D parametric curve".
papyblaise
Post by papyblaise » Wed Oct 21, 2020 8:28 am
use Part (I don't know how to do it in PartDesign)
Make a Helix, create a wide strip with Sweep, make a Common between a bowl copy and the spiral strip
draw the profile of the support and make a Sweep between this profile and the edge of the Common as a path
bowl.FCStd
(157.74 KiB) Downloaded 4 times
Greyble
Post by Greyble » Wed Oct 21, 2020 12:58 pm
First - thanks for all the prompt replies.
I was unaware of how useful and general purpose the online macro's could be - the '3d parametric curve' will be useful elsewhere.
Thanks to papyblaise - I was looking for a technique to solve this sort of interaction issue. This approach will also be very useful.
drmacro
Post by drmacro » Wed Oct 21, 2020 1:58 pm
Or with just profiles and the Curves workbench:
Spiral3D.FCStd
(452.58 KiB) Downloaded 4 times
My beginners, written treatise: Learning FreeCAD
mario52
Post by mario52 » Wed Oct 21, 2020 2:06 pm
hi
other idea Macro_FCSpring_On_Surface Image
Bowl00.FCStd
(112.77 KiB) Downloaded 2 times
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
Who is online
Users browsing this forum: Google [Bot], MisterMaker, philem and 15 guests
