newby needs help
rosen71
newby needs help
Post by rosen71 » Wed Oct 21, 2020 7:43 am
Hi there,
As completely new to FreeCad, I am learning the first steps thru all available tutorials, but got stuck with an issue I couldn't resolve.
Here is the situation:
I draw (Psrt Design) two figures. Let's say 2 squares with different sizes.
What I need is to put the smaller square, rotated at 45o angle, in the center of the larger square.
The socind isuue is how I can make the corners of the square to be round (with 3mm radius).
Your help will be highly appreaciated :)
Re: newby needs help
Post by chrisb » Wed Oct 21, 2020 8:42 am
For the square: You can switch the inner square to construction lines and place the corners in the middle of the construction lines using symmetry. Perhaps you don't even need the construction square, and use the outer points for the symmetries.
Sketcher has a fillet tool, which creates the necessary tangents, you only have to add the radii.
Besides that, you sketch is poorly constrained. You should prefer geometric constraints over dimensions. Repeating the same dimensions obscures the geometry behind and is prone to fail in case you have to change something.
papyblaise
Post by papyblaise » Wed Oct 21, 2020 9:18 am
draw the profile centered on the UCS, it will be easier
for the inner square, use the tool "Create a regular geometric figure" that you center on the UCS
carré centré.FCStd
(22.53 KiB) Downloaded 6 times
carré centré.PNG (17.19 KiB) Viewed 221 times
Bance
Post by Bance » Wed Oct 21, 2020 9:50 am
Why are you drawing all of something which is so obviously symmetric?
fcaduser
fcaduser
Post by fcaduser » Wed Oct 21, 2020 10:05 am
+1
Something strike me. The intrinsic geometrical propreties a lot of parts have is often underused. It should be a general advice : "Detect symmetries and linear/polar nets. It's always a saving."
And here, it's blatant.
rosen71
Post by rosen71 » Wed Oct 21, 2020 10:25 am
thank you for your answer, but I didn't get any idea what tio do, except the tangetnts.
You see the figure I am trying to draw, and I would be happy if can get a step by step guide.
On anothe note, I have a lot of drawing made in CorelDraw, which I can export in appropriate format (SVG), and once imported, i can't do anything with them.
rosen71
Post by rosen71 » Wed Oct 21, 2020 10:30 am
Dear,
I am completely new in this, and for you it may seems to be simple, but for me it is not.
I believe that step by step instruction woyld be better.
Bance
Post by Bance » Wed Oct 21, 2020 11:02 am
Have a look at this file:-
SYM_Bance.FCStd
(25.49 KiB) Downloaded 4 times
fcaduser
Post by fcaduser » Wed Oct 21, 2020 11:34 am
@rosen71
I perfectly understand that you are a newbie. My point was, before we can of course provide you a step by step explanation for a specific sketch, I invite you to develop the reflex i have mentioned.
Do you see the picture, for example ? There are two underlying polar nets, and imagine how tedious it would to sketch everything !
rosen71
Post by rosen71 » Wed Oct 21, 2020 12:33 pm
Thank you, but the dimensions are not correct.
Anyway, I have the drawings imported from CorelDraw in SVG format, but I don't know how do anything with them in FreeCad.
test_1.FCStd
(152.92 KiB) Downloaded 6 times
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], m0n5t3r and 26 guests
