newby needs help
newby needs help
Hi there,
As completely new to FreeCad, I am learning the first steps thru all available tutorials, but got stuck with an issue I couldn't resolve.
Here is the situation:
I draw (Psrt Design) two figures. Let's say 2 squares with different sizes.
What I need is to put the smaller square, rotated at 45o angle, in the center of the larger square.
The socind isuue is how I can make the corners of the square to be round (with 3mm radius).
Your help will be highly appreaciated
Re: newby needs help
For the square: You can switch the inner square to construction lines and place the corners in the middle of the construction lines using symmetry. Perhaps you don't even need the construction square, and use the outer points for the symmetries.
Sketcher has a fillet tool, which creates the necessary tangents, you only have to add the radii.
Besides that, you sketch is poorly constrained. You should prefer geometric constraints over dimensions. Repeating the same dimensions obscures the geometry behind and is prone to fail in case you have to change something.
- papyblaise
draw the profile centered on the UCS, it will be easier
for the inner square, use the tool "Create a regular geometric figure" that you center on the UCS
- carré centré.FCStd
- (22.53 KiB) Downloaded 16 times
- carré centré.PNG (17.19 KiB) Viewed 522 times
Why are you drawing all of something which is so obviously symmetric?
fcaduser
+1
Something strike me. The intrinsic geometrical propreties a lot of parts have is often underused. It should be a general advice : "Detect symmetries and linear/polar nets. It's always a saving."
And here, it's blatant.
chrisb wrote: ↑Wed Oct 21, 2020 8:42 am For the square: You can switch the inner square to construction lines and place the corners in the middle of the construction lines using symmetry. Perhaps you don't even need the construction square, and use the outer points for the symmetries.
thank you for your answer, but I didn't get any idea what tio do, except the tangetnts.
You see the figure I am trying to draw, and I would be happy if can get a step by step guide.
On anothe note, I have a lot of drawing made in CorelDraw, which I can export in appropriate format (SVG), and once imported, i can't do anything with them.
Dear,
I am completely new in this, and for you it may seems to be simple, but for me it is not.
I believe that step by step instruction woyld be better.
Have a look at this file:-
- SYM_Bance.FCStd
- (25.49 KiB) Downloaded 9 times
@rosen71
I perfectly understand that you are a newbie. My point was, before we can of course provide you a step by step explanation for a specific sketch, I invite you to develop the reflex i have mentioned.
Do you see the picture, for example ? There are two underlying polar nets, and imagine how tedious it would to sketch everything !
