Assistance Please - CAD for a 3D Block??
I've followed a tutorial 1_0_StartingToDesignWithFreeCAD.pdf and it all worked. So now I am trying to design a very simple block 70 x 40mm with a 12.5mm hole at one end and left hand corner constrained to XY0,0
But when I go to pad, I get this. Object in white, 1 click on Sketch yellow, I click on origin and then sketch and green and if I double click on Sketch I go back to Sketcher.
So perplexed??
OS: Windows 10 (10.0)
Version: 0.19.22988 (Git)
Hash: cdc01cb20cfa74079c45b9dc2dab81e3248b2aa5
Python version: 3.6.8
Qt version: 5.12.1
So perplexed??
Qt version: 5.12.1
- Block1.FCStd
- (5.55 KiB) Downloaded 7 times
Re: Assistance Please - CAD for a 3D Block??
You have a part (yellow steps) but no body (blue steps).
Don't go to Sketcher WB to make a new sketch, select new sketch from PD WB and a body will be created automagically.
Hello
Looks like you have not body, just a part. Beat me while adding screenshot
See here:
https://wiki.freecadweb.org/PartDesign_Body
See here:
- body.jpg (40.21 KiB) Viewed 332 times
Thanks.
Well confusing. Why have I got Part and not Body??
Pretty sure when I started it was Body after clicking on the icon. And now a load of error messages??
So, started again. Seemed to go OK. Then at pad got this:
Can't believe it should be this complicated. And this time, I just centred the rectangle on XY0,0. Think I really want bottom left hand corner at 0,0.
- Exercise2.FCStd
- (15.96 KiB) Downloaded 2 times
Possibly you slipped with mouse. Your part and body icons are above each other.
See if this works for you.
- body.gif (563.82 KiB) Viewed 286 times
That looks good. I'll try.
And constraining to XY0,0, I've selected left side, bottom left vertex and the xy vertex and ><. Rectangle jumps to 0,0 but have an error with the >< constraint.
Well, it has got someway there. Doesn't look like my dimensions of 70 x 40 x 40. Original rectangle was 70 x 40, and pad 40. And the pocket is only going halfway through instead of 40mm.
This time didn't try to constrain to left bottom corner.
- Block3.FCStd
- (33.37 KiB) Downloaded 2 times
good to see that you are not giving up. if one learns 3d modelling professionally, there are weeks long courses covering just the basics.
here is what you are designing with a different workflow, the one from part workbench.
it never hurts to see things from a different perspective.
- In a new document, (1) select the part workbench. (2) click the cube icon.
- (1) in the treeview select the cube. (2) in the property view, enter the length, width, height. (3) adjust the view with isometric view and fit all.
- (1) create a cylinder.
- (1) select the cylinder in the treeview. (2) for the diameter, bring up the formula editor by clicking first in the radius property to bring up the small circular icon at the right side of that field, click that icon to get the formula editor, enter the diameter value divided by 2. click ok. (3) change the height to 22.
- (1) expand the placement/position property, modify the z-value to -1. By making the height to 22 and moving it down by one, the cylinder is now protruding at both sides of the cube by 1. This is good practice to avoid flush faces for later boolean operations which can, but does not have to, cause mathematical errors later on.
- (1) select both parts in the treeview with ctrl click. (2) press the boolean cut icon.
- (1) expand the cut shape in the treeview
- (1) select the cylinder in the treeview (2) expand the placement / position property view
- (1) adjust the x / y position
- a block with a through hole
- (1) select the cut in the treeview – right-click and delete, or go to the edit menu and delete or just press delete key
- the underlying cube and cylinder are now separate and again part of you root tree
Oops was referring to your block1 drawing. Missed exercise 2.
On your block3 file you created circle sketch on XZ plane.
It is in the center of the block and you have to pocket and selet Symmetric to plane.
For fun try reverse and you will see pocket on other side of block.
You can also turn on visibility of Origin to help visualize.
Who is online
Users browsing this forum: GeneFC, Google [Bot], kes and 18 guests
