DogLeg solver
bambuko
DogLeg solver
Post by bambuko » Thu Nov 19, 2020 6:56 pm
18:46:16  Updating geometry: Error build geometry(14): Geom_TrimmedCurve::U1 == U2
18:46:16  Invalid solution from DogLeg solver.
Quick search, only found this:
https://tracker.freecadweb.org/bug_revi ... ev_id=2764
which unfortunately doesn't help me much :oops:
Any ideas? please
OS: Windows 10 (10.0)
Version: 0.19.22846 (Git)
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
kisolre
Re: DogLeg solver
Post by kisolre » Thu Nov 19, 2020 7:45 pm
There was a request to report such cases where DogLeg fails but LevenbergMarquard succeeds buy @Abdullah at that time, that is why I created that bug report. Could you provide the file where you get that error?
bambuko
Re: DogLeg solver
Post by bambuko » Thu Nov 19, 2020 8:09 pm
I think I have narrowed down the problem to a couple of fillets (problems started after I added them).
Testing at the moment to see if the problem is eliminated.
As for the file - I will see if can trim it down to just the problem geometry (it's a large one, where most of it doesn't matter and just complicate things)
kisolre
Re: DogLeg solver
Post by kisolre » Thu Nov 19, 2020 8:36 pm
Just copy the sketch in question to a new file. With all referenced external geometries and things linket through expressions if there are any. Should give the same result.
bambuko
Re: DogLeg solver
Post by bambuko » Thu Nov 19, 2020 8:42 pm
OK, will try tomorrow and see if the error is repeatable.
Re: DogLeg solver
Post by Kunda1 » Fri Nov 20, 2020 5:29 am
OP, you're also using an inferior version of v0.19. Please stay up to date and test on the latest revision. Thx!
bambuko
Re: DogLeg solver
Post by bambuko » Fri Nov 20, 2020 9:23 am
...Please stay up to date and test on the latest revision. Thx!
Sorry for slacking ;)
Have updated:
Version: 0.19.23058 (Git)
Hash: 6e60870ebcb2df018adb7a1281c00dde87750f11
Qt version: 5.12.5
OCC version: 7.4.0
and tested again - with the same result (i.e. Dogleg warning)
FreeCAD file:
Dogleg_test.FCStd
(244.67 KiB) Downloaded 10 times
To replicate, open spreadsheet and enter different values for "angle from back dead centre" (cell C4).
Eventually after few times (but not necessarily immediately) it will cause the error message.
I have also tested with fillets in "connecting rod" removed and could not get it to fail.
bambuko
Re: DogLeg solver
Post by bambuko » Sun Nov 22, 2020 4:14 pm
An update since the last post.
I have continued modeling without the "offending" fillets, alas it turns out that I was talking out of my rear orifice :oops: - the model without fillets just reported the same Dogleg error :roll:
Error message:
is the same as it always was :cry:
So clearly it must be something else...?
Model too large to attach, but if it helps with investigation, happy to share outside of forum.
One thing is constant - it always happens when I change dimension in the spreadsheet and model is recalculated afterwards.
and an hour later update - this is getting more interesting by the minute :mrgreen:
Re: DogLeg solver
Post by chrisb » Sun Nov 22, 2020 5:44 pm
The problem isn't the DogLeg solver, it's the spreadsheet. If you enter the value in C4 with the correct unit ° , e.g. 91° then it all works.
OS: macOS 10.15
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
bambuko
Re: DogLeg solver
Post by bambuko » Sun Nov 22, 2020 6:39 pm
The problem ...it's the spreadsheet. If you enter the value in C4 with the correct unit ° , e.g. 91° then it all works.
C4 is and always was entered as a degree.
Don't know what gave you the idea that it isn't entered as degrees?
Just for a sanity check I have re-opened the file I have attached in this thread and it clearly is degrees that are entered.
I am puzzled by your statement :cry:
Who is online
Users browsing this forum: alexu, papyblaise, thomas-neemann, wmayer and 13 guests
