Struggle with .step or .stl workflow
Hi all,
I've been trying to figure out a working workflow for how to modify some existing models. The .stl and .step file can be found here: https://github.com/Bemeier/bmek/tree/ma ... BottomCase
I tried using the following workflow to get the .stl file into a good state:
1. import the file
2. Using the Part workbench, convert it to a shape
3. Refine shape
The issue I run into with this workflow is the side of this model with the logo on it doesn't get cleaned up properly - the flat parts are still a series of triangles.
I tried the following for the .step file:
1. import the file
2. Using the PartDesign workbench, convert to body
What I'm stuck on here is what to do next. I tried extruding the logo for example, and I get a "No shape selected" warning.
What I need help with is getting the object into a state where I can begin editing it. For reference if it helps, two of the edits I want to make are clearing off the logo and modifying the rounded rectangle cutout on the opposite face.
FreeCAD version info:
OS: macOS 10.15
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
1. import the file
3. Refine shape
1. import the file
OS: macOS 10.15
Qt version: 5.6.2
Re: Struggle with .step or .stl workflow
Before you can work on an STL with the usual tools such as booleans or the PartDesign tools you have to convert the shape to a solid. This is done in Part workbench (see the menu).
Such a solid, and it's the same with an imported step can be seen as a base block with nothing more than faces, edges and vertices. You cannot change any of these (exception: see below).
But you can well add and subtract material. So after having created a body with the STEP as BaseFeature you can add sketches and create pads and pockets.
If you only want to remove things from the solid, you can use Part->Defeaturing. Be warned that this is not parametric.
Thanks chrisb!
I do have a sketch mapped to a face once I have a body from the .step file. I don't know how to then take a feature from that existing body (circular cutout for example) and generate a shape in the sketch based on it. Thats the big gap for me preventing me from creating pads or pockets.
You should first learn the very basics. Look at the PartDesign Tutorials, they will show you what you need to get going.
Would that help ?
Both of what you guys linked me to does help. For the kinds of things I'm trying to do, what are all the workflows/tools I should work through tutorials for? I'd be happy to step away and read up/practice, I've been struggling with not knowing terminology and where to start.
This is my $.02...it's probably worth less.zeuser wrote: ↑Sun Nov 22, 2020 4:42 pmBoth of what you guys linked me to does help. For the kinds of things I'm trying to do, what are all the workflows/tools I should work through tutorials for? I'd be happy to step away and read up/practice, I've been struggling with not knowing terminology and where to start.
You are attempting to use geometry created in a way that is not native to FreeCAD. Once it is converted to a form FreeCAD can interact with, i.e. a solid, then FreeCAD can cut away or add, but can't change it's inherent shape. So, even then you need to understand how to use the native tools that add and cut away.
Learning to use a new, complex tool, with information, foreign to FreeCAD, is going to be an up hill battle. Knowing how the tool works in it's native way is essential. (I.e. learn to walk before entering a marathon so to speak...)
There are plenty of folks on Youtube showing the use of imported geometries. I'm not sure there is any one that captures all the subtleties.
To actually get a basic intro of how, at least, the Part Design workbench can be used, try the intro that is listed in my signature below.
(Not implying it has any instruction about imported (step or otherwise) geometry, just FreeCAD basics.)
My beginners, written treatise: Learning FreeCAD
another 2 cents...
i would say stl is just for rendering, or modelling for purpose of rendering, i.e. computer graphics
step is a more design like format - but not really for editing either - main practical purpose is interchanging dead models, but this time with continuous surfaces - so the format works when that is important (read any manufacturing industry).
for an editable file - unfortunately one is stuck with the software it was created on - it kind of sucks, but not much to do about it.
if you are looking at doing things as in the video - your best bet is then modeling from scratch - does not take that long and you have it fully editable, your main use of the step in that case is to just take measurements off it, and compare so that they are the same when you are done.
what tutorial? any tutorial that gets you going towards a complete remodeling from scratch, most people recommend part design for that.
once you can do some modeling from scratch - you either feel comfortable enough to just do it from scratch, or you will know enough to find your way of how to start using donor models.
Thanks All! I was starting to come to the conclusions you guys are drawing. I may try either using the reverse engineering tools, or asking the creator of the designs for measurements and trying to recreate the files.
By any chance, are any of the other supported filetypes easier to work off? I can maybe ask the creator to share those with me if they are able.
I would agree that stl is pretty much only good for tracing over.
STEP on the the other hand can be more useful, though, still not as useful as modeling from scratch.
For example, this is the STEP model imported into FreeCAD: Adding a boss is almost trivial in Part Design:
Or extract the face of the object to get a sketch with all the pertinent geometry: Then make your additions and simply Pad: Since an STL file is a bunch of triangle connected together to look like the model, this would be more difficult. But, actual faces in a STEP do have some advantages.
Who is online
Users browsing this forum: Google [Bot], papyblaise and 15 guests
