Hi ! I am new here so greetings to you all! I have searched..and tried but is there a way or format I can import into Sketcher! I want to make my 2d lines in Moi 3d and add constraints in Freecad and export to Moi 3d via iges! Import and export via iges isnt the problem..but into Sketcher...of Freecad....!
thanx in advance!
Hi! Is there a way or format to import into Sketcher from Moi3d?
Re: Hi! Is there a way or format to import into Sketcher from Moi3d?
Hi and welcome to the forum!
You cannot modify the geometry of an imported object in FreeCAD directly. You can, however, downgrade until you have appropriate wires which you can convert in Draft workbench from draft to sketch.
The way back depends on your model and may be difficult.
