B-Spline crashing Freecad in dev version 0.19
Re: B-Spline crashing Freecad in dev version 0.19
Doing a complete uninstall (used Revo) and then a re-install the problem still exists. I tried with a different mouse and the problem still exists.
Errors after clean install are below:
What else can be done to isolate the error?
Log
Python Console
Log
Module: Part
Loading Part module... done
Loading GUI of Part module... done
Loading Sketcher module... done
Loading GUI of Sketcher module... done
Sketcher::setUpSketch()-T:0
Sketcher::Solve()-DogLeg-T:0
Sketcher::setUpSketch()-T:0.001
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Access violation
The event type 12 was sent to QOpenGLWidget
Object tree:
QOpenGLWidget is child of
SIM::Coin3D::Quarter::QuarterWidget is child of
QStackedWidget is child of
Gui::View3DInventor is child of
QMdiSubWindow is child of
QWidget is child of
QMdiArea is child of
Gui::MainWindowSketcher::setUpSketch()-T:0
Object tree:
QWidget is child of
Gui::MainWindowUnhandled Base::Exception caught in GUIApplication::notify.
Unhandled exception in ViewProvider::eventCallback: Access violation
(Event type: SoLocation2Event, object type: SketcherGui::ViewProviderSketch)
Python 3.6.6 | packaged by conda-forge | (default, Jul 26 2018, 11:48:23) [MSC v.1900 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.activateWorkbench("SketcherWorkbench")
>>> App.newDocument("Unnamed")
>>> App.setActiveDocument("Unnamed")
>>> App.ActiveDocument=App.getDocument("Unnamed")
>>> Gui.ActiveDocument=Gui.getDocument("Unnamed")
>>> Gui.activeDocument().activeView().viewDefaultOrientation()
>>> App.activeDocument().addObject('Sketcher::SketchObject','Sketch')
>>> App.activeDocument().Sketch.Placement = App.Placement(App.Vector(0.000000,0.000000,0.000000),App.Rotation(0.000000,0.000000,0.000000,1.000000))
>>> App.activeDocument().Sketch.MapMode = "Deactivated"
>>> Gui.activeDocument().activeView().setCamera('#Inventor V2.1 ascii \n OrthographicCamera {\n viewportMapping ADJUST_CAMERA \n position 0 0 87 \n orientation 0 0 1 0 \n nearDistance -112.88701 \n farDistance 287.28702 \n aspectRatio 1 \n focalDistance 87 \n height 143.52005 }')
>>> Gui.activeDocument().setEdit('Sketch')
>>> import Show.TempoVis
>>> ActiveSketch = App.ActiveDocument.getObject('Sketch')
>>> tv = Show.TempoVis(App.ActiveDocument)
>>> if ActiveSketch.ViewObject.HideDependent:
>>> objs = tv.get_all_dependent(ActiveSketch)
>>> objs = filter(lambda x: not x.TypeId.startswith("TechDraw::"), objs)
>>> objs = filter(lambda x: not x.TypeId.startswith("Drawing::"), objs)
>>> tv.hide(objs)
>>> if ActiveSketch.ViewObject.ShowSupport:
>>> tv.show([ref[0] for ref in ActiveSketch.Support if not ref[0].isDerivedFrom("PartDesign::Plane")])
>>> if ActiveSketch.ViewObject.ShowLinks:
>>> tv.show([ref[0] for ref in ActiveSketch.ExternalGeometry])
>>> tv.hide(ActiveSketch)
>>> ActiveSketch.ViewObject.TempoVis = tv
>>> del(tv)
>>> if ActiveSketch.ViewObject.RestoreCamera:
>>> ActiveSketch.ViewObject.TempoVis.saveCamera()
>>> App.ActiveDocument.Sketch.addGeometry(Part.Circle(App.Vector(-61.508595,30.987280,0),App.Vector(0,0,1),10),True)
>>> App.ActiveDocument.Sketch.addGeometry(Part.Circle(App.Vector(-50.558201,3.494806,0),App.Vector(0,0,1),10),True)
>>> App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Radius',0,5.000000))
>>> App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Equal',0,1))
>>> App.ActiveDocument.Sketch.addGeometry(Part.Circle(App.Vector(-20.735853,20.968842,0),App.Vector(0,0,1),10),True)
>>> App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Equal',0,2))
>>> App.ActiveDocument.Sketch.addGeometry(Part.Circle(App.Vector(-7.455585,-8.387534,0),App.Vector(0,0,1),10),True)
>>> App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Equal',0,3))
>>> App.ActiveDocument.Sketch.addGeometry(Part.BSplineCurve([App.Vector(-61.5086,30.9873),App.Vector(-50.5582,3.49481),App.Vector(-20.7359,20.9688),App.Vector(-7.45559,-8.38753)],None,None,False,3,None,False),False)
>>> conList = []
>>> conList.append(Sketcher.Constraint('InternalAlignment:Sketcher::BSplineControlPoint',0,3,4,0))
>>> conList.append(Sketcher.Constraint('InternalAlignment:Sketcher::BSplineControlPoint',1,3,4,1))
>>> conList.append(Sketcher.Constraint('InternalAlignment:Sketcher::BSplineControlPoint',2,3,4,2))
>>> conList.append(Sketcher.Constraint('InternalAlignment:Sketcher::BSplineControlPoint',3,3,4,3))
>>> App.ActiveDocument.Sketch.addConstraint(conList)
>>> App.ActiveDocument.Sketch.exposeInternalGeometry(4)
>>> App.ActiveDocument.recompute()
?Could the issue be that I have Python 3.8 in my Path before FreeCad, and Freecad seems to be built on Python 3.6?
I have been using lots of different versions of FreeCAD for years on both Windows 7 and Windows 10. I have absolutely nothing in any Path (user or system) related to FreeCAD.PJtraveler wrote: ↑Wed Jan 13, 2021 4:53 pm ?Could the issue be that I have Python 3.8 in my Path before FreeCad, and Freecad seems to be built on Python 3.6?
At one time I had links to Boost, Python, etc., and they sometimes caused problems.
FreeCAD for Windows is stand-alone. It needs nothing linked from Path.
Gene
Gene,
Thanks for your input
I've deleted Python from the system and the problems still persist, although I am now able to move the control points before FC crashes.
Did you ever install FreeCAD? That may do additional things beyond just unpacking.
Can you please test starting freecad using this batch file:
- unzip batch file into that folder, where freecad.exe could be found.
- double click freecad.bat in file explorer.
I installed the release version of 0.18, but I did not install any version of 0.19 because there is no installer.
Frankly I do not remember if anything was added to Path when 0.18 was installed, but I had been messing around with Boost and Python as I noted earlier. If anything was added to Path by the 0.18 installer I probably removed it a long time ago.
The point was that there is no need for any FC links in Path.
I also avoid allowing anything to install in the Program Files folder if I have a choice. Windows does all sorts of strange things (protections) to stuff installed there. Of course that means I need to trust that FC is not malware.
Gene
Right you are!
Sometimes I get a little wistful when I think that there were times when a program was uninstalled by simply deleting a folder.
The .bat file was a good suggestion !
FC will not start with an empty path!
Graphviz is in the path, I thought FC required Graphviz.
I'll work on isolating what FC needs from the path
